Old 04-17-2003, 09:21 AM
other tom other tom is offline
Default Re: Bracket mounting question
Your bracket will be custom made anyways, and yes, they can build it to accomodate a 30" shaft engine. You want the bracket mounted as low as possible to get the most flotation though so it will look a bit odd. Jackplate by CNC will do the trick. Are you stuck with a 30" shaft motor? It sounds like you have a 25" transom now...
