Re: twin 200's on 23
I recently purchased a 75 23' cc that has a stainless marine bracket and twin 1999 200 Mercury EFI's. I have only run the boat 3 times since I bought her and amd in the middle of putting in a new deck, painting everything and replacing all of the hardware. The boat is scary fast. I did not have my handheld gps when I got both motors up to 5000 RPMs but I know it was over 50 mph. Even with the floatation bracket the boat is a little heavy in the stern. I have put a little weight in the forward locker and this has gotten rid of this problem. I wish I could give you some numbers but I won't be able to for a while. I currently have a 120 gallon tank I am going to add another tank in the space right in front of the console. I think I will be able to add another 50 gallons or so up there. That will put more weight forward as well. I do have a 50-60 mile run each way to the gulfstream from where I put in though. I do think some 150hp engines wiegh identical to 200hp engines so you might want to see if you are really adding any weight or just more power.
CMB
Good luck with everything!
