Old 07-24-2003, 01:17 AM
TUGBOAT TUGBOAT is offline
Default Re: Transom Concerns?
I had a similar problem on My 20 MA . Although I had NO Flex,some stress cracks. it had a plate to fix an earlier prob.(how Long ??) I ran it 4 years with no prob. I went to re-install a transducer & noticed wet/watery wood when drilling.Drilled a few 1/4 inch holes from the inside(hidden) transom.some not much was dry.Patched the holes.Pondered what to do for a while(long).I ended up replacing the transom with composite/Hi density foam.
If You have a reasonably strong transom & want to patch it for awhile, till the timing or $$ is right put a plate on it.seal it good & ride.Otherwise just fix it & let another Boating Problem come along.
Scream'n reels' [img]images/icons/cool.gif[/img]
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
