Re: Transom Concerns?
GREAT ADVICE GUYS!!!!!!
That is what this board is all about! Keep up the good work.
My advice is to use a 1/4 inch drill and open one or 2 holes where the hollow sound is coming from about 1 inch in. Check the overall condition of the wood. Dry rot, solid, moist, mush etc. etc. Just to be sure, drill one or 2 holes near the lower drain holes at the bottom of the hull about maybe 2 inches up. Does water drip out overnight, if so how much a cap ful or a few ounces.
This is what I did and it really gave me all the info I needed. Just epoxy the holes up and noone will know.
If you are not rotted, perhaps a steel plate would sure things up until you decide how much $$$ you are willing to spend. Remember, this would be a good time to bracket!!!!
Capt. Brian
