Thread: RePower?
Old 08-31-2003, 10:07 PM
Roland Rodriguez Roland Rodriguez is offline
Default Re: RePower?
Welcome to the site. I run a 1970, 20 ft master angler and yep...fighting yellow lady. I had a 1990 225, 25 inch shaft. Pictures are on the site in the 20 footers. My transom was redone and it was rebuilt 25 inch instead of the 20. I run the boat with a jackplate. The wieght is an issue as she squats a bit at the rear and I have to plug the thru deck self bail holes before I board her. I have updated the engine with a 97 oceanpro 225. I would suggest building up the transom to 25 inch. Its do able.....Those OMC engines when properly taken care of and having at least 95 lbs of pressure will run and run and run. Let me know if there is anything I can help you with... I'm in Miami myself....see you at the sandbar
