Re: Mercruiser electrolysis / merCathode ?
THe Bravo 3 drives have a problem in this area. All your bravo series comes with the MerCathode set up if your repowering. What gives this drive problems is the stainless wheels. THe MerCathode system works off of 12 volts from your battery. Its very important to be sure its hooked up right to the battery. 99% of the problems can be found by a good dealership that will come out to your boat when its in the slip. They will have a meter that they can read the voltage around the drive. Also be sure to use the oem zincs over the aftermarket ones.
