Old 03-05-2002, 11:03 AM
Default Re: PRICE ON A 225 YAMAHA 30"
HA SCOTT
I DID THE TRANSOM WITH THE WEST SYSTEM AND 2 SHEETS OF Ύ” MARINE PLY WOOD. I ALSO ADDED A Ύ” WIDE SUPPORT TO THE INSIDE OF THE HULL FROM THE TRANSOM TO THE BOTTOM OF THE ENGINE WELL RESTING ON THE CENTER STRINGER AND GOING FORWARD ABOUT 1 ½’ WHERE THE OLD LIVE WELL USE TO BE FOR ADDED SUPPORT.
I RE DID THE DECK WITH ½” MARINE PLY AND WEST SYSTEM AND TOOK THE CAP OFF FLIPPED IT OVER AND RE DID IT AS WELL WITH ½ “ MARINE PLY. BUILD A NEW LIVE WELL WITH FIBERGLASS AND INSTALLED IT WHERE THE NEWER SEACRAFTS PUT THERE LIVE WELL MINE IS 32 GAL WITH A THROUGH HULL SCOOP AND PUMP. MOUNTED THE TRANSDUCER THROUGH HULL ON THE CENTER LINE ABOUT 2’ FROM THE TRANSOM.
I ALSO REBUILT THE GAS TANK DECK OF Ύ” PLY. FOR A 120 GAL GAS TANK FORWARD OF THE OLDER 100 GAL THAT WAS ORIGINALLY THERE. THE NEW TANK TAKES UP THE AREA UNDER THE CENTER CONSOLE SO NOW I DON’T HAVE A STEP DOWN AREA UNDER THE CENTER CONSOLE I WILL INSTALL THE OIL TANK AND BATTERIES AND A FRESH WATER TANK UNDER THE CENTER CONSOLE ON THE FLAT DECK ABOVE THE GAS TANK. I AM STILL FAIRING AND PAINTING HOPE TO BE DONE SOON.
FELLOW-SHIP
