Old 04-11-2002, 10:26 PM
capesams capesams is offline
Default scott---info.76
Scott:
went in the files this is the best I can do for ya.
centerline.......23'.3"
beam.............8'
height,keel to top of w/shield....6'4"
draft,hull,o/b tilted.....16"
weight,dry[w/o engine...2650#
o/b cap.-max.total weight: persons,motor & gear in lbs....3185#
max total o/b h/power.....400....?..twins
degree deadrise........20
min.cocpit depth[at stern]....25"
fuel cap. [useable]...ob100 gal.
***ice boxes,two 20 qt,insulated,w/overboard drains
baitwell- 120qt.
fishbox-390 qt.
transom reinforcing, full width fiberglass 13/8 plywood.
Old 04-11-2002, 11:51 PM
Scott Scott is offline
Default Re: scott---info.76
Thanks Steve
I'm surprised at the Hp rating....thats more than todays 23...
Thanks again!!!
Old 04-12-2002, 09:56 AM
HA STEVE
THERE LOOKS LIKE SOMETHING IS NOT CORRECT ON THE WEIGHT THING.
HOW CAN THE BOAT WEIGH 2650 LBS. AND THEN MAXIMUM TOTAL WEIGHT ONLY BE 3185
BOAT 2650
ONE MOTOR 500
PERSONAL EFFECTS 150
GAS 500 OR MORE
TWO PEOPLE 400
__________
TOTAL 4,200 LPS
FELLOWSHIP [img]images/icons/confused.gif[/img]
Old 04-12-2002, 12:08 PM
Fellow-Ship
I interpreted that a different way...
As in thats additional to the hull weight...For instance Briguy's boat...motors and fuel alone are almost 2,000 lbs then another 1,000 for gear tops people.... your at the 3,000 mark
I originally thought that too....as a single motor and 100 gal. of fuel alone would push you over that limit..
Old 04-13-2002, 01:34 AM
GUY's:
the info. I gave was right out of the book. letter for letter.
