Old 08-09-2004, 10:12 PM
pdmattox pdmattox is offline
Default gear oil leaking
wondered if any one knew why gear oil would leak from a small hole on the lower unit. I think i have "R" drive.
Old 08-14-2004, 10:52 PM
Default Re: gear oil leaking
Possibly the shift shaft seal, assuming you're speaking about the small drain hole near the front of the lower unit, about 1" below the upper edge.
Fr. Frank says:
Currently without a SeaCraft
Old 08-16-2004, 08:41 PM
Thank you for your reply. I guess i need to by a repair manual so i can fix. I run in salt water so hopefully i caught it early enough.
