Old 11-27-2005, 12:25 PM
JW-Tex JW-Tex is offline
Default Low tech floatation-2 litre
I recently read an article on Howard Hughes Spruce Goose test flight, the plane was aparantly filled with beach balls to act as emergency floatation, the article indicated this was atypical and the norm for a sea place test was to use ping pong balls. After the test flight the beach balls were given to the spectators.
When I awoke last night to feed my five month old twin boys last night inspiration hit me. Empty two liter coke bottles for under deck floatation instead of foam. How much floatation would get from a 2 litre coke bottle? Would they fit under the deck of a 20 SeaCraft after it is raised 3 inches?
Just a strange idea...
JW
Moesly 1969 20 CC & Potter 1978 23 CC (23 in storage awaiting rebuild)
Old 11-27-2005, 12:36 PM
PressureDrop PressureDrop is offline
Default Re: Low tech floatation-2 litre
that ideas been tossed around - but if they were just hanging out down there when ever your running im sure the sound would be annoying. i think someone mentioned putting as many 2 liters as you can and then foaming it cause it would weight less and in the event that water does get in you will still have flotation even if the foam is all wet... lots to think about [img]/images/graemlins/confused.gif[/img]
no falls, no balls
Old 11-27-2005, 04:04 PM
RS RS is offline
FWIW, about 4.4 pounds in fresh water, slightly more in saltwater.
Best regards,
Roger
http://members.cox.net/rhstg44/Misc/...go%20small.jpg
1979, 20' Master Angler
Old 11-27-2005, 04:42 PM
Ikan Besar Ikan Besar is offline
JW
Maybe not so strange: I know someone who used the regular 16oz soda bottles for under-deck floatation. When you think about it, there shouldn't be any UV breakdown concerns and they are individually sealed in case of the hull being breached.
The only question remaining is how long would it take to drink an adequate amount of diet Pepsi to have enough bottles to fill the boat?! [img]/images/graemlins/tongue.gif[/img]
Old 11-27-2005, 04:47 PM
we will all just have to start drinking the beer that comes in the plastic 16oz. bottles. With projects getting started for the winter, shouldn't be more than a week before we have a good supply of floatation devices.
Old 11-27-2005, 05:33 PM
I've been toying with the idea of filling several 6ft lengths of 2" PVC tube with cocaine (using pvc caps + epoxy and cabosil to seal the ends), foaming them in the cavities (under the floor), and running drugs. What do you guys think? [img]/images/graemlins/smile.gif[/img]
Seriously . . . the bottles are not a bad idea unless the containers fill up with water (somehow).
This is completely off topic . . . but 2 liter bottles - (filled with water and frozen) are a great inexpensive way to keep you fishbox cold all day long.
Old 11-27-2005, 05:34 PM
John R John R is offline
But going back to the Spruce Goose, how about modern ultralight ping pong size balls?? Or does that lose to much space between them?
For the professional [img]/images/graemlins/cool.gif[/img] - what about a shape that interlocks and would fit tight??
Surf and Boat fishing for
Striped Bass
Old 11-28-2005, 10:53 AM
Bryan A. Bryan A. is offline
An old Yankee Boat builder in Connecticut by the name of Earl Brockway was known to use old light bulbs as floatation in the seats of his plywood skiffs.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
Old 11-28-2005, 04:07 PM
How about just buying the second bilge pump and use it if needed. I think that’s what the make them things for. What do you think?? [img]/images/graemlins/crazy.gif[/img]
FellowShip [img]/images/graemlins/grin.gif[/img]
Old 11-28-2005, 04:41 PM
I actually have three bilge pumps and two batteries, my 1969 hull has no foam floatation at all...and being a former owner of a "heavy" (water saturated foam) Whaler I am not a fan of foam.
JW
