Old 04-18-2006, 12:38 PM
thewalshies thewalshies is offline
Default livewell
Can anyone explain how the original "freeflow" livewells worked on the 20's? Is there a better way to rig it? Thanks.
Old 04-18-2006, 04:41 PM
caper caper is offline
Default Re: livewell
I'm anxious to hear some answers to that question as well.
Old 04-18-2006, 10:07 PM
Phan000 Phan000 is offline
Not sure how it was originally rigged, but mine was modified to section off the livewell at the aft end of the well. I drilled a hole in the bottom of this section and installed a bildge pump.
It was designed for a livewell so it came with a screw on screen for the baitwell side. It pumps the water out through a hose that runs through the actual bildge and through the port side of the boat well above the waterline. I just open the four plugs and let it "freeflow".
The only problems with this system is that the plugs pop out unintentionally when I am running fast. I could probably fix this with some new plugs but I am too lazy too buy them.
I can post photos if you are interested.
Old 04-19-2006, 06:48 AM
Sounds intersting, pics would be great, please post.
