Old 06-23-2006, 05:44 PM
SkinnyEd SkinnyEd is offline
Location: Tallahassee, Fl but will be relocating within the next year
Default question on stringers
I'm a novice at his so forgive if I have a stupid question.
I know I have some transom rot and am definitely looking at a replacement job there.
I thought perhaps the stringers would be a problem with rot too but have seen some posts referring to the stringers being of foam and not wood.
Can someone tell me what the composition is for sure and whether the foam stringers are a potential problem area?
My boat is a 1975 20 SF with outboard power.
1975 20 SF "Good E-Nuff"
Old 06-24-2006, 09:02 AM
Bryan A. Bryan A. is offline
Default Re: question on stringers
I have the same boat but a 73 and it has foam filled stringers, yours should be too. The foam could be wet but they are usually pretty good, you could open up a few test holes.
Try a site search for stringers as this has been discussed many times before. Hope that helps. Good Luck.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
