Old 06-25-2006, 11:47 PM
Default i think i spun my prop... help
guys i think i spun my prop because the boat runs a little different now... doesnt get up on plane as fast as usual but rpms are screaming. so got home and looked at the prop and its loose on the shaft. the nut is still on and so is the safety pin. any body know of a place in miami to fix this ? or can i do it myself? thanks
-evan
Old 06-26-2006, 02:05 PM
Default Re: i think i spun my prop... help
Any prop shop or the prop guys do pick and drop off at all the marinas, not expensive and common.
Old 06-27-2006, 02:21 PM
yup....you spun the rubber hub, about $50 to have re hubbed
Don Battin
Pipe Dreams Marine
"Design her right,
Build’er well
Bend the throttles,
And let’er eat…."
Carl Moesly
Old 06-27-2006, 10:25 PM
im getting my old one rehubbed. it was 15x17. went ahead and bought a new prop also. went to a 14.5x19. hopefully get more than 35mph at 5k like i am now.
Old 06-28-2006, 09:50 PM
http://www.gpcprop.com/
Old 06-29-2006, 10:25 AM
RS RS is offline
Spun props usually don't allow you to even get on plane, but a loose prop that allows exhaust gas to ventilate will do that. Try tightening your prop first. If you're lucky, that will be it.
Of course the mystery is still how it would have loosened in the first place since the castle nut and cotter pin are still there.
Best regards,
Roger
http://members.cox.net/rhstg44/Misc/...go%20small.jpg
1979, 20' Master Angler
Old 07-01-2006, 11:01 PM
the nut and cotter pin were still there. since i put on the new prop and hub the problem is a thing of the past. boat is alot faster with this new prop i put on. i got 39 mph at wot 4800. 1985 evinrude 150.
-evan
Old 07-02-2006, 06:33 PM
Best RPM for that motor is 5200 to 5400, @ 4800 it will have a slow hole shot and you won't lose top end may even get more going down 2" in pitch.
Old 07-03-2006, 01:23 AM
so if my current prop is 14.5 x 19 u say i should go to a 14.5 x 17? i used to have a 15 x 17 and i only got 5000 rpm at 35mph.
-evan
Old 07-03-2006, 08:24 AM
All is not a matter of pitch and diameter. Rake, cup, and shape of the blades all make a big difference.
Fr. Frank says:
Currently without a SeaCraft
