Old 02-18-2007, 12:42 PM
RODMAN RODMAN is offline
Default Limited ClassicSeaCraft Rod
Here's the scoop.
RodMan is willing to to make a custom "Classic Seacraft" limited rod. A lamiglas 40lb rod blank with wrap cork grips,fugi reel seat,and fugi silicon nitride II rings(wire or mono).Option roller tip (Aftco) or regular tip (fugi)either can be used for mono or wire.Color of rod can be white, black, or honey.This rod retails for app. 400.00 in Conn.and in black retails for app. 600.00.(Hard to wrap black on black)
I would like to make a black rod with gold accent,(gimble,reel seat,and thread)labled,
Limited Edition
Classic Seacraft 1 of 1 2008
Rome's Custom Rods
Owner's Name
All proceeds (It will be an on site bidding ) will go to this site and I will even pay for the shipping. This site has given me so much info. that its my turn to give back.
I will post photos of a rod that I built which I would like to build for this site.It is black with gold accent and looks great.This would be a limited edition to only one rod per year and I would like to do this every year (only one rod per year) if it sounds like a good idea I would like input and any ideas to make this work.
(I have built this rod for commercial fisherman on Cape Cod for striped bass and they love it).
I have had this rod with a penn 349(wire) to a everol(mono) and pulling in a 40 lbs. plus stripers, great rod action.
Photo will be posted--
Old 02-19-2007, 11:46 PM
Default Re: Limited ClassicSeaCraft Rod
Here are the photos Any input will be taken into consideration and will be open to debate.Thanks
This is a used rod but what the new rod will be built to look like and the lettering will be in gold. "There can only be one"
Old 02-20-2007, 11:20 AM
peterb peterb is offline
What length???? And you said that the rod can be used with either mono or wire????
Old 02-20-2007, 01:53 PM
nestorpr nestorpr is offline
Looks real nice, great work!
Boatless again!
Old 02-20-2007, 08:56 PM
It is a seven foot rod,the guides on this rod are fugi's new saltwater concept made from silicon nitride II,you can even run wire line through them and they are 30% lighter than the standard heavy duty guides,the frames are made from stainless steel,black chrome finish to fight corrosion.The roller tip is aftco,some guys like roller tip with wire and some like standard tip for mono (sometime mono or superbraids can get pinched or jamed in the roller tip),either tip will handle wire or mono.For a long time they used carbide guides,try switching a old salt,-- He loves the rod,stated"wire line goes through the guides just as smooth as mono".
Thanks Botapeje and Peter
