Old 02-01-2009, 05:56 PM
rhody98 rhody98 is offline
Default seafari bilge thru-hull
Adding a second bilge line, it will have its own discharge. Existing discharge thru-hull is an elbow on starboard side about 6" from transom, tight space in liner really does require an elbow. The stock through-hull is a bronze (brass?) elbow, looking to duplicate for new bilge discharge (1-1/8") on starboard.
Rule makes an elbow but it is high impact plastic, really prefer metal. Any recommendations on where I can find a decent match or even stainless thru-hull elbow?
Old 02-01-2009, 06:49 PM
Default Re: seafari bilge thru-hull
Hey Rhody, Try these guys.
http://www.jamestowndistributors.com...pid=14976&BASE
All the boat building going on there, I'm sure you can find these locally for less.
Maybe Rich at Cape Marine Supply can source you a deal.
Good luck. Saw your cap leak post - going through the same deal...
Old 02-02-2009, 09:08 PM
Thanks Gilly, that one all the other decent elbows I see are 1" or 1-1/4", not 1-1/8". May just have to go with a straight fitting which there are plenty of and try to get the hose in there.
Old 02-02-2009, 11:13 PM
Rhody,
I may be mistaken but I think the measurement given for the elbow fitting (1") would be its inside diameter. It's gotta have some thickness to support a hose clamp so its outside diameter is probably right about 1-1/8". The 1-1/8" bilge hose should have a snug fit over the barbed nipple for clamping.
Hope I didn't over think this
Old 02-03-2009, 12:56 AM
I went to the specs at the Groco web site, actually you have to be careful. The elbows like you found - the pipe OD matches up with hose ID.
For the straight through hull fittings you can order either of 2 models for each fitting size. For example the 1" straight fitting has two models, one for 1" hose the other for 1-1/8" hose. Go figure.
Old 02-03-2009, 04:40 AM
Alright Rhody,
Here's my final offer but you're gonna have to ante-up, see if this works.
http://www.gemlux.com/catalog.aspx?p...arch=THRUHULLS
Old 02-03-2009, 08:14 AM
thanks Gilly
you aint kidding on the ante up part
Old 02-03-2009, 11:32 PM
toddslures toddslures is offline
I sent you a pm. I can help you out on Gem parts.
www.toddslures.com
Old 02-04-2009, 01:22 AM
thanks indeed
Old 03-22-2009, 08:32 PM
Here's where this ended up. $200+, about 4 hours install to add a second, independent bilge pump. Rule 2000 dedicated discharge and runs off 2nd battery. At 8+ amps you wouldnt want this running off the battery alone for very long. I see this basically as a back-up/redundant/emergency set-up that hopefully is never needed.
The aft pump is the existing Rule 1500, runs off the other battery. I put the float on a wedge wood block glassed and painted, sits about 2" higher than the other float. The two will give a theoretical pumping capacity of 3500 gph, actual probably closer to 2500. We will do the old bucket test later after the batteries are in.
The only waterproof panel switch I could find was Blue Seas, which is pricey. Right of the wheel.
SS through hull on the port side. Thanks again Todd.
