Old 05-18-2009, 11:40 AM
fdheld34 fdheld34 is offline
Default REMOVAL OF PITTING ON WINDSHILED FRAMES
Tried to search for topic..but no hits....
What is the best way to remove light pitting from the aluminum windshield frames......sanding???? buffing???? what type of buffing compound etc...etc???
Any help appreciated.
-FRED
Old 05-18-2009, 11:58 AM
PressureDrop PressureDrop is offline
Default Re: REMOVAL OF PITTING ON WINDSHILED FRAMES
the easiest way to remove the pitting is to remove the windsheild frame altogether all kidding aside i really dont know, suppose you could try an flitz it.
no falls, no balls
Old 05-18-2009, 12:41 PM
I think filling it with some kind of fairong compound is the only way to fix it....I'm intending to try the alumaprep, alodine and awlgrip prime/paint. Since I have them off my Tsunami working on them should be easy enough.
Old 05-18-2009, 04:38 PM
htillman htillman is offline
I had my frame off the boat and the glass removed and used a razor scraper & WD 40 to lightly scrape the pits off. It cleaned up pretty well, I tried a bunch of chemicals but found the above cleaned the pits off rather easily.
Old 05-19-2009, 09:17 AM
Ben..my wife would kill me...she might get wet ....I will try the flitz and also the razor and WD40..not bad enough to fill...just annoying surface type pits and streaking...mabey even some brasso...or that wadding cleaner that comes in a can ..cant remember the name
thanks all
-Fred
Old 06-02-2009, 10:53 PM
Tiny Tiny is offline
The woody wax products work pretty well, leave it on for 24 hours, then use copper steel wool to rub it down...
