Old 04-11-2010, 02:11 PM
jwclbi jwclbi is offline
Default Plexiglass windsheild
Finally got my 37 year old windsheild off my center console and was wondering if anyone has made one these on their own. I found the right size piece of plexi and was thinking a heat gun would heat it up enough to bend? Also any tricks to cutting it? The piece is 1/4 " Thanks any info would be great!
Old 04-11-2010, 04:17 PM
Default Re: Plexiglass windsheild
Last time I cut plexi I put plywood blade backwards on the tablesaw. I think I also ran some masking tape on the cut line. for curves go with jigsaw w/a fine tooth blade and take your time. Tape is also good here, although the material usually comes with a plastic film on both sides
Make sure you ventilate well.
Can't speak to the bending but heat should do the trick.
Old 04-11-2010, 05:27 PM
Hi jwclbi:
I made my own but used Lexan not Plexiglass. You can use a thinner sheet for Lexan and it will not crack and break. I used a heat gun and supported both sides with wood clamped together and then exposed approx 1” or 2” space in the middle and bent. It came out good and I have bent some other things since then.
Here is a thread on it.
http://www.classicseacraft.com/forum...=&fpart=1&vc=1
FellowShip
Just for the Grins
Official Antique Classic SeaCraft Owner
Old 04-11-2010, 06:40 PM
aldo aldo is offline
Plexiglas is less likely to bubble than lexan. I use a device called a strip heater specifically made to bend plastics.
Old 04-11-2010, 07:49 PM
I use a Strip heater as well.
They work great!
See ya, Ken
Old 04-11-2010, 09:05 PM
jeff6645 jeff6645 is offline
Very informative web site and videos.
Jeff Pettit
Pettit & Pettit Enterprises
Mobile, Al.
1974 23' Yamaha 250 OB
Love My Classic Seacraft
Old 04-12-2010, 09:41 AM
Hope it works for you. If it doesn't, try these guys...
http://www.updplastics.com/seacraft%...indshields.htm
Old 04-13-2010, 02:01 AM
CaptSeaCraft CaptSeaCraft is offline
Call American Plastics in Camarillo,Ca.If you can draw it I believe he'll make it for you for a smok'n deal.Lexan will Chex faster in the sun and does eventually get brittle.Overall Plexi would be a better choice and you can have the edge/holes flamed so they'll be stronger.Just a thought from a Journeyman glazier/boat glass fabricater of 23 years.
I have owned Classic 23 and 18 foot CC Mako's...They were nice but My Classic SF18 SeaCraft is where its at!
Cant wait till I can get a Master Angler!
