Old 04-22-2011, 02:05 PM
Default Bracket on a 20
I am currently running a 20" transom on my 20MA.
Most engines are 25" shafts and I know some where down the line I will want and will have to replace the transom to a 25" transom . I have a line on a really nice Merc 200 OptiMax with very low hours that I can get for cheap
My question is could I not do a bracket and use a 25" engine till I redue the transom. I know I should just bite the bullet now and relace it but not now, I would rather start using the boat this summer and I like the boat with the engine on the transom. Here is pic of the bracket that I would use
[image][/image]
Old 04-22-2011, 05:40 PM
Ryan Ryan is offline
Default Re: Bracket on a 20
Jorge, youre gonna take lots of water over the stern with that setup on an open transom, Remember patience pays do it right the first time and youll be happier in the end.
Old 04-22-2011, 06:01 PM
Yea I know I'm just going to look for a 20" shaft engine
Old 04-23-2011, 12:02 AM
bitsamonkey bitsamonkey is offline
Don't do it. Get a 25" motor and if the transom is in decent shape, raise it to 25". You don't have to replace it to get to 25". There are no suitable modern motors to run on a 20" transom. I know from experience, made the same mistake.
Old 04-23-2011, 09:12 AM
CaptMick CaptMick is offline
Jorge,
I may have a 20 in. 150HP 4S Suzuki w/o lower unit available. If you are interested I will talk to the boss about letting it go.
Mick
Old 04-23-2011, 10:15 AM
Confused... how do you use a 25" engine on a 20 transom???
Old 04-23-2011, 10:33 AM
Jorge,
Mick
PM me your number
Old 04-23-2011, 11:31 AM
Sorry, I meant raise the transom to 25" by glassing it.
Old 04-23-2011, 12:24 PM
1970 1970 is offline
Jorge, there is a 1985 Johnson GT 150 20' for 1k on craigslist in stuart. Some new parts says runs great.Sounds temporary for you so maybe this will do for the summer. Good luck
Old 04-23-2011, 02:06 PM
Looking at the following engines
1 1994 Yamaha 225 20 inch shaft with prop says 110 psi across the board asking $2500.
2. 1993 Black Max 150 says very clean (pics looks like it) says 145psi across the board asking $2400
3. 1999 Yamaha 150 carb says 550 hrs with 140 to 145 psi asking $3100
4. 1988 Merc 150 says 125psi on all 6. Has a 20 inch mid and stock lower unit has spacer for 25" shaft also asking $1200
5.late 90's Merc 175 says 130's compression on all cylinders 20" shaft asking $1900
And finally my preferece is
Merc Opti Max 200 low hours (can't remember year). This is a mutual friend of mine that works for Mercury he gets a GREAT discount on a new engine every so often. I spoke to him a few weeks ago but was traveling. I want to say he was asking $3500 only thing it's a 25" shaft. If I can get this one for $3000 I'll raise the transom.... but let's see on this one
OPINIONS WANTED PLEASE!!!!!!
