Old 01-30-2012, 06:49 PM
Finster Finster is offline
Default Grounding Plates
Anyone have any thoughts on this? My Alpha I outdrive seems to have a lot of electrolysis, the zinc's melt quick. Would a bronze grounding plate help this? Or should the boat be grounded already though the outdrive?
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
Old 01-30-2012, 07:52 PM
Finster,
I'm no marine electrician but have a '78 I/O Sceptre 23 (7.4L Bravo One) with a lot of metal in the water (beside the outdrive, have Kiekhafer tabs, transducers, etc.). I mounted a large transom-mounted zinc plate and have all underwater hardware bonded together with #6 wire and to the zinc plate itself. I also have a Guest Dynaplate (sintered bronze ground plate) that was used as a ground for my old Furuno loran, but the ground plate itself is not going to help reduce your electrolysis; if anything, it would probably help make it worse with more noble metal underwater.
I also keep up with my outdrive and tab mounted zincs carefully and so far have had no real problems with a now 20+ year old outdrive and my tabs still look like new (I am sure I just jinxed myself by typing this). Sorry I cannot upload any pictures just now.
Old 01-30-2012, 08:03 PM
Thanks. Ya I should probably recheck all my ground again. It's no biggy replacing the caviltation plate zinc once a month if I can't find anything.
'76 23 SC CC I/O
Old 01-30-2012, 08:34 PM
Yo Scupper Lips
Why don''t you just wear these Zic plated underwear and hang your big toe over the side while your trolling
Old 01-30-2012, 09:23 PM
Damn Chuck, I'm so glad I don't know what that is, but questioning the fact that you do...:P
'76 23 SC CC I/O
Old 01-30-2012, 09:28 PM
Yo Scupper Lips
Or that, that should work too.
Old 01-30-2012, 09:30 PM
Originally Posted by Finster View Post
...It's no biggy replacing the caviltation plate zinc once a month if I can't find anything.
If you're going through zinks at that rate, there's probably something wrong. Water Rat's right about the bronze. If it's in the water, it's only going to make things worse.
If there are other boats moored close by, one or more of them may be introducing stray current into the water. I'm not sure how you would check that. Maybe if you put on Capt. Chuck's zinc plated undies, stick a toe in the water and lick the negative battery terminal. If it tingles there's probably stray current.
An alternative is to use an induced current system (to fix the galvanic corrosion, not to find the stray current). Merc makes one for the Bravo drives called Mercathode. It seems to have fixed the corrosion problems they were having. I don't know if it will fit an Alpha, but it probably won't. There might be a way to rig it, though.
Dave
Blue Heron Boat Works
Old 01-30-2012, 10:00 PM
Ya I'm thinking dead short somewhere, though I couldn't find anything last year. Shutting the batteries off doesn't seem to help either. I'll just go through everything again and or try Chucks undies. Thankfully I won't need to use my toe
'76 23 SC CC I/O
Old 01-30-2012, 11:18 PM
BigLew BigLew is offline
Com'on Finney, use the toe. You were the first to admit there was probably a "dead short!"
Plan accordingly!
Old 01-31-2012, 08:11 AM
bly bly is offline
Default Does anyone even use grounding plates anymore?
on the 20 potter project I am doing now. It had one probably from the old loran days? I removed it and glassed over the holes? No one uses them today that I have seen. especially outboards with no shore power. In fact I have seen many larger CC boats with shore power and No ground plate?
