Old 05-23-2012, 09:39 PM
Default Fast trac tnt q`s again.....
Hi all.
Ok, so when we last left our heros, I had found and installed a fresh water unit.
It was a cheap mop and glow re do. Chinese motah and no seal kit. Rustoleum job.
So I wanted to do it properly and got an Arco motah and seal kit for the original. Rebuilt in the living room on a clean piece of marble. Rams were perfect and due care exercised. Zinc chromate 3 coats. Bedliner 2 coats. Factory spray bomb 3 coats.
Manifold re-mounted and rams extended empty. Yeah I know. On advice from Arco, I am touching the switch for a sec up and down. Re Pete. Re Pete. She is taking factory fluid so the pump must be working. Still no movement. Cap off and not dumping out of the fill.
Confused as always,
GFS
Thanks gang!
