Old 12-28-2012, 09:19 AM
nitz nitz is offline
Default Open transom cover.
Thought some of you guys with older Seacrafts with open transoms might be interested in this cover I made.
I have been working on the engine cover for my 1988 25' Sea Vee.
As you can see, open transom which allows water to splash in while drifting or backing up offshore. Decided to go with a two piece cover. The bottom piece will be attached to the boat with screws and the top part will hinge on the bottom piece.
Started by making a female mold for the bottom piece from scrap plywood I had laying around. Used some leftover body filler to make the radius. I will shoot it with primer and auto paint next week then wax it and make the part. The recessed area will allow the motors to be tilted almost all the way up for transport or whatever. I left enough of space under the bottom for your feet or to allow for cleaning etc...
Old 12-28-2012, 12:01 PM
That looks cherry. Nice work!
Old 12-28-2012, 12:57 PM
Bryan A. Bryan A. is offline
Looks great!!
But, do the motors tilt??
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
Old 12-28-2012, 01:25 PM
Very nice! I'm always impressed with high quality custom fiberglass work. A lot of guys with 20' SeaCrafts and later 23's would benefit from this type of design.
Old 12-28-2012, 02:25 PM
VERY nice work! Will the top piece you mentioned will bring it to the full height of the transom?
Old 12-29-2012, 09:30 AM
The motors will not tilt up all the way, but they will come within a couple inches of full tilt which is fine for towing, etc... If I get a new tie rod that is not offset then they will go all the way up.
Old 12-29-2012, 09:33 AM
The top piece will go all the way over the motors like on a 27 conch. It will have a bait prep station on top, and reduce the engine noise significantly. I might put a rod holder or two on it as well. It will be removable for trailering or maintenance.
Old 12-29-2012, 09:36 AM
I am also going to upgrade to the extreme model shift cables (tighter allowable bend radius 4" instead of 8"), and redo the rigging tubes so that they aren't in the way.
Old 01-06-2013, 05:27 PM
weir mako 21 weir mako 21 is offline
Nice glass work...and those rare Merc 500hps must fly! What type of hinges are you planning for the upper section?
-John
Old 01-06-2013, 06:08 PM
Nice work. It takes a pretty mold to make a pretty part.
Dave
Blue Heron Boat Works
