Old 06-26-2013, 06:13 PM
abl1111 abl1111 is offline
Default Gelcoat matching
Anyone provide the basic colors and volumes needed to get close to the SC hull color ?
i.e. 1 oz of white gelcoat, 4 drops of this, 2 drops of that...
Old 06-27-2013, 01:22 PM
Yellow and brown. I keep trying and I always over pigment the brown. It is very little. I don't have a recipe, but that's a start.
Old 06-29-2013, 08:40 AM
Thx Fish,
No one on this site has done this type of color match synopsis ?
Wow - you guys have over-engineered, invented, re-invented EVERY aspect of our beloved SC - but not how to match the gelcoat ?!
I'm surprised at this gaping hole in our community !
Old 06-29-2013, 09:25 AM
If I had to guess, in a pint of mar-pro white (not neutral), I'd say 3 drops of brown and a few of yellow. I tried just brown and messed it up. Getting drops out of tube of pigment is tough, it can come out fast.
Old 06-29-2013, 09:27 AM
Use a toothpick to transfer small amounts of pigment.
Blue Heron Boat Works
Old 06-30-2013, 09:23 AM
One more thing. Different years are different tints, I think. My 71 Seafari 25 is darker than my 75 MA 20. Or that's my impression.
Old 06-30-2013, 06:26 PM
fg1 fg1 is offline
Correct. Different colors for different years and even if the colors were originally identical, a 5 year old boat would not be the same color as a 20 year old boat.
Start with a tiny bit of yellow until your close but lighter, then add tiny amounts of brown until you get it. It will cure slightly lighter. Make small batches ' cause you're gonna throw some away!
Old 06-30-2013, 07:48 PM
bgreene bgreene is offline
Suggestion - use WAY LESS pigment than you believe appropriate- just a tiny drop.
Then mix very thoroughly and first compare to the untinted gel coat in the can.
You'll be surprised that it will show the impact of such a small tint.
Then put a little dab on the boat - see how it matches up. Add a very tiny bit more tint if needed.
Over adding color is WAY easier than you'd think.
Old 06-30-2013, 08:29 PM
Guilty of overeating hot dogs as charged. Seems to dry darker as I watch Homer sing
with Deano. Put it on a piece of wide clear tape.
Cheers,
Us
