Old 09-03-2014, 09:59 PM
Captbubba69 Captbubba69 is offline
Default 1989 20 Seacraft
Never had a Seacraft before and I'm looking at a 1989 with a 140 Suzuki.
Boat was recently redone by a boat yard.
Seller mentioned Seacraft was bought by Tracker. Is this a concern? Was Potter the designer? What should I look for? Deck fuel tank and transom are newer as in redone within 2 years....
How fast should this boat run? I don't want to put my kids in a 40 knot death trap.
What's the difference between the late 70's and late 80's 20 foot hulls?
Thanks!!
Old 09-03-2014, 10:00 PM
Some pictures.......
Old 09-03-2014, 10:02 PM
Zzzzzzzzzzzzzzzzzzz
Old 09-03-2014, 11:51 PM
That looks like a good find with nice power! Your console is much narrower than the one that came in my '89, definitely an improvement. Has it been changed? Also check carefully around the mounting screws for the console and leaning post for soft spots or any movement. Mine was soft around every screw. It was balsa core and the rot hadn't gotten too far out so I was able to cut out small circles of balsa and recore instead of having to do the whole floor. I responded to your other thread and I hope this helps.
Rod
Old 09-04-2014, 01:30 AM
its a lot narrower then my 82
82 seacraft 20SF
Bayview Canvas
Old 09-04-2014, 06:55 AM
Looks to be a nice hull, check for soft spots due to tracker used ply wood in the deck instead of the better balsa wood and it may rot out faster if water ever gets in it. The water will spread threw the ply much faster than balsa. Also check the transom for strength.
Is this the same one that had the yammaha on it that didn't run that has been repowerd?
Old 09-04-2014, 07:08 AM
Thanks for the feedback.. Here's a few more
Old 09-04-2014, 07:12 AM
I think last one....
By the way thus is a great site. I've been around boats my entire life n always admired Seacraft boats. I've built our 2 privateers, had 2 webbers coves, BHM, Stevenson, ton of water logged makos, bunch if whalers
Old 09-04-2014, 07:14 AM
My big girl....
28 BHM built in Maine. 3116 turbo cat....23.9 knot boat.... Cruises at 16-18 knots..... Thru anything u put in front of it....solid fiberglass..... When fiberglass was fiberglass....
Old 09-04-2014, 07:30 AM
Default Bubba Fleet
Nice addition to your fleet, Capt. With probably one of the best power options for a 20' Seacraft. I think you are set for a while.
