Old 11-19-2013, 08:52 PM
verch verch is offline
Default 20' max motor weight
Can anybody tell me what the max motor weight is for a 20'er? I'm considering a F150 which weighs almost 500lbs. Currently running a F115 and its a little lacking on top end.
Old 11-19-2013, 09:12 PM
That's a lot of weight. Guys do it but these were designed for 300 lbs motors. Experiment with props before ruining the ride of her. If you do go with the 150 move everything as far fwd as possible, tank, batteries oil, console, everything and get trim tabs, that is a must
Old 11-19-2013, 11:25 PM
Getting an optimal prop would be a much better idea. Even the F115 is heavy for these boats.
Trying 2 or 3 props is also far cheaper than a repower.
Old 11-21-2013, 08:52 AM
Thanks for the input guys. I'm really leaning toward keeping the 115 and adding trim tabs for a slower plane.
Old 11-21-2013, 08:44 PM
I put a 2001 200 merc on this summer it weight 416 pounds on the tag, mny scupper are still just out of the water at rest and when I stand in the back the water only gets the gutters in the deck wet sd fif the 93 150 evinrude I took off
82 seacraft 20SF
Bayview Canvas
Old 11-25-2013, 03:45 PM
Thats what I have too and about the limit
Old 11-27-2013, 12:03 AM
Thanks for all the input. The boat is new to me as of a couple weeks ago and I'm used to going a little faster but I could definitely get used to the quiet motor and good fuel efficiency of the F115. I think I'll give it a fair shot before considering a replacement.
Old 11-27-2013, 02:09 PM
jwclbi jwclbi is offline
I have a 1998 Merc 225 EFI weighing in at 475lbs on my 20 SF and it still self bails. The transom has seen its day after 40 years but i leave the plugs out at all times
Old 01-06-2014, 04:01 PM
jesse@tsiaviation.com jesse@tsiaviation.com is offline
I have an 18' powered with a 150 Salt Water Series Merc 2001,' the scuppers sit below the waterline.
Old 01-06-2014, 06:51 PM
maybe move the batteries under the console or something, all V6's weigh about the same but I have 2 under the console as far as possible and it bails at rest until some 200+ person going to the back - depending fuel and baitwell load
my '94 200 weighs in at 415 - seems the 98 225 weighs a bit more
it seems the Yamaha's are the weight pigs of all brands?
