Old 01-06-2014, 10:07 PM
gchop gchop is offline
Default Fuel tank two pickups
Fuel tank in my 23cc has two pickups in rear of tank. What would the reason be ? They where both plumbed to my filter.
Reserve ? Twins ?
Old 01-06-2014, 10:44 PM
You joined when?
Old 01-07-2014, 12:02 PM
I guess i missed something.
Old 01-07-2014, 02:23 PM
me too.
I personally don't know why there would be two. i have never had twins but that would be my only guess.
Old 01-07-2014, 02:30 PM
hermco hermco is offline
Common practice. Most tanks will have two. I recently rerigged a Zodiac RIB from a single to twins and the tank had two pickups. Just had to run the hose and install filter.
Old 01-07-2014, 02:47 PM
Two pickups are provided for two engines and two separate filters. Running two engines off one filter isn't real smart for several reasons . . . besides setting yourself up to allow one clogged filter to shut down BOTH engine, twice the flow rate thru one filter will:
- cause the filter to clog faster,
- increase the pressure loss and flow restriction, increasing the probability of starving the engines for fuel.
Starving an engine for fuel not only reduces power, (AND lubrication, if running an old carb'd 2-stroke on primix!) the resulting lean mixture significantly raises combustion temperatures, leading to overheated pistons, causing them to scuff the cylinder bores if they don't completely seize or come apart! Ethanol-laced gas contains extra oxygen so it burns even hotter. The old carb'd 2-strokes were jetted relatively rich to begin with, so had more margin, but the newer motors calibrated for low emissions and better gas mileage are relatively lean to begin with so are more sensitive to fuel starvation.
Fuel starvation and the resulting lean combustion has probably killed more engines than any other single cause and it doesn't take long to do it! This is why it's wise to do a compression check if buying a used motor. Over-powered rigs are probably the most susceptible because a slight loss in power is less noticeable, and the natural reaction to a slight loss in rpm, especially if you have lots of power, is to just bump the throttle up a bit instead stopping to try to figure out what the engine is trying to tell you! Advancing the throttle just makes the failure happen faster!
Old 01-07-2014, 04:48 PM
ok that anwsers that.
next question: both pickups were plumbed to a single filter with one outlet to the motor
( 250 suzuki 4 stroke ). is this neccesary ? Im guessing I should fabricate the new tank with two pickups if a future owner wants to put twins.
opinions please
thanks, G.
Old 01-07-2014, 06:16 PM
I say build it the way you want it. If you got a single plumb it for a single. No sense in trying to predict the future.
Old 01-07-2014, 06:20 PM
Maybe they used both pickups for a single engine and filter just to minimize flow restriction between tank and filter, but that shouldn't be necessary if the individual pickups are large enough (3/8" diameter). I'd have the tank built with two pickups for possible future use with twins.
Old 01-07-2014, 07:01 PM
You joined when?
You have to expect this type of response from Sandy. I think everyone in the forum has been down this road. Lol...
