Old 12-24-2017, 02:18 PM
Surfnski Surfnski is offline
Default HermCo Bracket Installation Question
I just picked up a used Hermco twin bracket for my 23 center console project. I’m planning on hanging a single 250-300 4 stroke 30” shaft engine on it. Can anyone advise to what the mounting height of the bracket should be off of the keel?
Thanks in advance for your replies.
Old 12-24-2017, 03:44 PM
manitunc manitunc is offline
30" from center of keel to flat part of platform. The rise due to setback is accomplished by the engine mount tab.
Old 12-26-2017, 09:29 AM
I mounted mine higher due to my raised deck and where the bolt holes would come thru on the transom. I can't remember how much but it was at least 1 or 2". This worked out very good for me as others have complained they can't get their single 30" motor high enough. Even with raising my bracket higher my motor is mounted on the second to last hole from the highest setting. If you are going with a single motor I would highly advise you go up at least 1.5" higher than the instructions say. The pic below was before I moved the motor up.
Old 12-30-2017, 01:48 PM
Thanks for the responses guys!
Moose- Does your bracket have a 30” setback? Looks like it could be less in the picture. I will definitely consider the extra height when I bolt it up.
Old 12-30-2017, 02:20 PM
It’s a 30” bracket.
Old 12-31-2017, 11:17 AM
Moose,
Would you happen to have the installation instructions for your bracket laying around? I wouldn’t mind getting a copy if it’s not too much trouble to send me a scan or even a photo of the documentation. I sent Don Herman an email about getting a copy but I haven’t heard back from him yet.
Old 12-31-2017, 01:22 PM
Default Twin bracket, single engine
Attached are Don's instructions when I bought mine.
Old 01-01-2018, 12:18 AM
Great info thanks! Is there a diagram that goes along with it? Is point A is the keel?
Old 01-01-2018, 12:09 PM
Attached is what Don sent.
File Type: pdf Twin Bracket Single Engine Diagram 1.pdf (11.3 KB, 104 views)
File Type: pdf Twin Bracket Single Engine Diagram 2.pdf (100.2 KB, 81 views)
Old 01-01-2018, 02:26 PM
Thanks for posting the PDF's guys! I'm looking forward to rebuilding my transom and getting this bracket mounted.
