Old 12-04-2017, 08:33 PM
bdenman bdenman is offline
Default For Sale 1986 SEACRAFT 23’ CC With 2017 300 hp YAMAHA
Had always thought I would keep this forever even when I re-powered this spring but have decided to move up.
Not gonna say it’s a fishy boat but if you don’t catch fish it won’t be the boats fault!
I guess the Seacraft hull speaks for itself but with this engine the boats performance is really impressive! Speed is pretty linear with RPM’s (3000RPM=20mph 4000=30 5000=40 etc.) and the boat jumps onto a plane even when heavy.
She tops out just shy of 50 but I was focused on the cruising speed and fuel burn which seems to be maximized with the Yamaha 15/17.5 STS Prop the boat can get 3mpg @ 30 miles an hour and the STS prop is great with the bushing that cushions the shift into forward or reverse.
Boat has always been well cared for and maintained, engine and gear oil changed after the 20 hour break-in and again @120 and will have a 3rd when it gets winterized
Brand new 2017 Yamaha 300 with 205 hours this season
Engine is mounted on a hydraulic jackplate with 12” set back and 6” lift
Also new in ’17;
Simrad GO9 GPS/fishfinder with chirp and Totalscan Transducer
Leaning post cushion
Complete Bottom job with epoxy barrier coat and Petit vivid white ablative bottom paint
Deck job and fresh non skid
Salt Water Washdown
Major refit in 2009 including;
New 130 Gallon Fuel tank and Deck work
Edson Wheel with Edson knob
Complete wiring job
Blue Seas Battery switch with charging isolator and has 2 gel batteries
Raymarine E80 with thru hull transducer
ICOM VHF
Boat is setup for bass and tuna fishing and has 6 Lee’s HD Swivel rod holders as well as 4 other standard holders
Magma 44” Filet table mounted in the stern Above the engine for easy bait rigging, measuring fish, fileting
Included in the sale a 2012 Loadrite “Elite”Aluminum I-Beam Tandem torsion axel trailer with disc brakes in good condition
Asking $32,900
Boat is Coast Guard Inspected for up to 50 miles and Safety gear could be negotiable for an interested buyer
