Old 10-18-2021, 07:23 PM
Seacraftwalkaround Seacraftwalkaround is offline
Default Scepter 23’
Do the potter built 23’ single outboard scepters have same problem with scuppers being too low. Is raising deck necessary?
Thanks
Old 10-19-2021, 09:13 AM
I'll be curious to know this answer too. I have a 75 Tsunami but it has a Mercruiser 350 IO in it. It is a wet boat when people stand in the corners. I would like to, and probably will raise the deck at some point.
Old 10-19-2021, 12:00 PM
bmajvi bmajvi is offline
I think it depends on how you use your boat, and what you expect. The design of the "drains" that go through the bottom of the boat can allow seawater in, if a lot of weight is placed in the stern. I had an 18' SF and now own a 23' Sceptre with an outboard on a bracket. Both of mine were kept on a trailer with the drains unplugged, but I put plugs in when I put the boat in the water, so I've haven't had a "wet feet" problem. If water accumulates in the boat because of people climbing into the boat from the water, rain, etc., it's a simple matter to pull the plug and let the water drain out - it seems a little odd to have "a hole on the boat" but it works, as long as you don't have a bunch of weight in the stern at that moment - the water in the boat is above the sea level, and "water seeks it's own level" and disappears down the drain.
If you keep your boat in the water you wouldn't want to plug the drains though, as rainwater would accumulate. The design and original construction of the drains includes wood blocks that can rot and lead to water entering the boat too, so many guys have raised the deck and installed different style scuppers to resolve these issues.
1977 23' Sceptre
Old 10-20-2021, 12:30 PM
Where are blocks? Can’t get access without ripping deck up?
Old 10-20-2021, 02:18 PM
Inside the hull wherever there is a drain. The block was to give enough thickness to use flared or threaded thru-hull fittings.
Old 10-20-2021, 02:19 PM
And yes...most of them are buried.
Old 10-20-2021, 02:44 PM
FLexpat FLexpat is offline
Very hard to get to without cutting deck. After I redid mine, I figured out a way to redo using pourable (Seacast) without cutting deck. It would have been much easier but I am not sure of strength difference. I did not raise my deck much - just 1/4" to make bond with new deck on old lips.
Old 10-21-2021, 06:58 AM
TMala TMala is offline
Flexpat- can you walk us through the process of how you did that?
Old 10-21-2021, 10:55 AM
Gimme a bit - it's gonna take some writing and drawings to make sense. Remember that I cut my decks for what I did, but figured out how I SHOULD have done it afterwards. Hindsight 20/20, it is what I should have done even with the decks cut out.
Old 10-21-2021, 02:59 PM
Petey Petey is offline
Take a look at my build the boondoggle you can see in the pics were the blocks are. You may have to remove the back cap to get to them. I removed everything so it was easier.
