What is the best type of drainplug for the drainhole at the bottom of the transom on my 20' Seafari? I thought the hole would be threaded, but it doesn't appear to be....
And, should it be installed from the outside or the inside? I want to keep this boat floating !! Thanks! Steve
"why are you buying such an old boat?" 1974 SeaFari V6 i/o, 1965 Bowrider 19' i/o, 1975 Sceptre 23' i/o, WS Tarpon and Hobie kayaks, 12' Starcraft tin boat |
Well, you have a choice. You can remove what is in there and replace it with a threaded one or, just use a good quality rubber plug, installed from the outside. I guess you could install it from the inside however, that will require you to get down in the bilge every time you pull the boat. Do not use a cheap plug, simply because it will not last long.....
John I support the "Hot Boat = Hot Chick" theory. |
I used 1in PVC shd 40 to keep the water from the transom core. It was glued in by using epoxy/cabisol. I then installed a Garboard plug on the outside. The inside flange fitts inside of 1in PVC perfect.
Make sure you install the plug that gets screwed in with the small T-handle, not the type with a flip-handle. The flip-handle can get flipped by the water force, seaweed, flotsam, etc. and fall out of the boat without your knowledge.
Boatless again! |
I install mine from the inside. Just reach into the bilge and pull it out when trailering from the water.
I have used the T handle type rubber plug on my 20' SC for over 10 years without a problem. I install it from the outside because with the I/O it is difficult to reach from the inside.
Paul, 1989 23' SC CC 250 hp Suzuki Four Stroke on Stainless Marine bracket |
I've had both the rubber type as well as the threaded bronze version and have not had any troubles with either. I have always installed them from the outside.
