Old 04-06-2005, 01:18 PM
Blue Blue is offline
Default Gas tank installation
I am looking for insights on the types of plastic I should as strips to 5200 to the base of an aluminum fuel tank in order to raise it up. I am ready to put it in and was planning on glueing (5200) it to the floor of the box and doing with out foam.
1973 20 cc
Thoughts / suggestions?
Narragansett RI
Old 04-06-2005, 02:53 PM
SCSeacraft SCSeacraft is offline
Default Re: Gas tank installation
Blue,
I used 1.5 inch strips of .5 inch starboard and ran them lengthwise down the tank to let any water flow out and to allow air to criculate around the tank. I used plenty of 5200 to completely seal the starboard to the tank and not allow any air pockets where the white rust can have a chance to attack the tank.
Hope this helped.
Donnie
Old 04-06-2005, 03:07 PM
I read some where to use Fiber reinforced plastic. I can't imagine it maks that big of a difference. What about plexi or something cheap? A 5 foot sheep of starboard is pricey.
Narragansett RI
Old 04-06-2005, 03:38 PM
Starboard and 5200 don’t work together very well. I went to Home Depo and found some plastic fence material that they sell there cut it up to the proper sizes and glued it to the bottom of the tank let set and then used those two fat beads on both sides of the strip to hole tank to the deck. I think plexi glass is a much more ridged and breakable material and could become a problem if it breaks up over time with a boat pounding on waves.
I did my boat over 3 years ago and have not had any indication of a problem but unless I pull the tank hatch cover up I probably will never know for sure. Don’t use rubber it will rot and cause problems as time goes on. I wonder if you could use strips of fiberglass paneling would not rot but it would flex and you could make or cut them yourself?
FellowShip [img]/images/graemlins/cool.gif[/img]
Old 04-06-2005, 03:52 PM
RS RS is offline
I think you can find Trex, plastic lumber, at Home Depot or Lowes. It's made from recycled plastic bottles. 5200 should stick well to it.
Did you repair the old tank or replace it?
Best regards,
Roger
1979, 20' Master Angler
Old 04-06-2005, 04:04 PM
I ended up replacing it. It had a few quality holes where the rubber was on the bottom and where the foam was on the top. Trex is a good idea I will check in to that today.
I was hopeing not to foam it in at all just adhere it to the bottom of the well and tie it in to the stringers. Any thoughts on that approach?
Thanks,
Blue
Narragansett RI
Old 04-06-2005, 07:04 PM
paulfurnari paulfurnari is offline
We used neoprene strips 2-1/2" wide length wise glued with 5200 on an epoxy coated tank as per S&P Sheetmetal, making sure you seal completely. L brackets welded the length of the tank on top were secured to the stringers with some starboard blocking and stainless screws-no foam. It worked out great. - PF
Old 04-07-2005, 07:00 AM
RS RS is offline
Check out this article http://www.yachtsurvey.com/fueltank.htm
Best regards,
Roger
Old 04-07-2005, 12:30 PM
I did not have any problem with the 52oo and starboard set up and king kong coulden't get the strips off of that tank.My only regret is the size of the tank 130 gallons and with the new 4 stroke I would love to have that weight back but my range should be nice.
Donnie
Old 04-06-2005, 09:46 PM
salvagefirst salvagefirst is offline
im getting ready to put mine in soon,and im thinking about ripping some 1/2 marine ply into strips screwing it to the board then glassing it over, sand and put 5200 on it. Les
