Old 03-06-2006, 06:16 PM
oldbluesplayer oldbluesplayer is offline
Default yanking out the toilet -
yeah, I know, -head-.... well...
My '73 20' Seafari has an old, overboard discharge, head, which I want to remove, and replace with a portapotti, easier to deal with. Need to get this done soon, this spring, before I can go fishing for landlocked salmon in the New Hampshire lakes. The head is plumbed with two thru-hulls, intake and discharge - this is the real question -
How to block off the thru-hulls, when I pull the head ? There were no sea cocks on either line, which doesn't thrill me.
Are there solid (no hole) thru hull replacements available, which could just be installed into the holes ? If not, just a short piece of hose and a plug, attached to the thru hull, and double clamped at each end ? Are there thru hulls made with internal pipe thread, where a NPT plug could be screwed into the thru-hull?
Or is there no other way around, than to glass over the holes ? I'd rather avoid this approach, until the weather gets significantly warmer, and more conducive to doing fiberglass work outside.
Whatever route I take, I want to be significantly safe: Lake Winni is damn cold in the spring, and come summer the boat will be out in the Cape Anne/ North Shore area chasing blues, stripers, and hopefully, tuna.
thanks
Bill
Old 03-07-2006, 03:26 AM
Default Re: yanking out the toilet -
Unfortunatly the safest way is to glass over them on both the inside and underside of the boat. That is the safest and most bullet proof way to go.
Old 03-07-2006, 12:06 PM
Bryan A. Bryan A. is offline
What about a quality piece of hose connected to both and double clamped like you said. Basically allowing the water to go in and out between the fittings. Then you can use the boat and fix it right when the weather is warm. That is assuming the current through hulls are in good condition.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
Old 03-07-2006, 01:15 PM
the current, existing thru hulls are not the same size - inlet is a 3/4 (I think) and the outlet is 1-1/4 or 1-1/2 ??
so that keeps that solution out of play.
I'm thinking short stubs of tube, 3 or 4 inches working length, insert a plug in one end, double clamp that, and double clamp to the thru hull.
see the seperate post on stripping the old bottom paint - I would also want to wait on just glassing over the thru hulls till I get the paint stripped off the bottom.
was hoping there was a thru hull filler out there someone knew of - a thru hull shaped piece with no hole, meant just for this occasion.
Bill
Old 03-07-2006, 01:41 PM
I guess the different sizes would make sense to allow for "things" to flow out
Parker 2530 DVEC
Old 03-07-2006, 04:05 PM
QUESTION??
Why do the call it a head when it is designed for your tail??????
FellowShip
My motto: Just for the Grins
Old 03-07-2006, 04:46 PM
hermco hermco is offline
Head
The term comes from the days of sailing ships when the place for the crew to relieve themselves was all the way forward on either side of the bowsprit, the integral part of the hull to which the figurehead was fastened.
