Just repowered my 23 sceptre with a Johnson / Suzuki 225. Mechanic installed a 4 blade 14.5x17. with a 2.3 reduction, this is way underpropped. Numbers are 9 mph @3000 - 15mph @3500 - 19.5 mph @ 4000 - 28 mph @5000 - 31 mph @ 6000
My target was 28 mph @ 4000. Can anyone who is running a 225 four stroke on a 23 share their prop size and speed numbers so that I can see if I'm on target. Trying a 16x17 this weekend. Not sure what to expect. Thanks
1985 23 Sceptre 225 Johnson Four Stroke |
increase pitch to increase top speed and lower rpm. I would try a 19 but a 21 might be better depending on the load in the boat
A 3 bladed prop is more efficient prop to use as well.
FellowShip _______________________________________________ My motto: Just for the Grins ![]() |
I would think you should be able to get 40+ with the right prop. Your speeds VS RPM seems awfully low, but I run a 2 stroker on my 23WA and get 42/43 mph trimmed out at WOT.
http://www.rbbi.com/folders/prop/propcalc.htm This will give you a prop calculator site. Maybe that will help.
Gary |
Tried a 15.5x19 three blade this weekend. 5,500 WOT gave 36 MPH. 4,000 gave 25 mph and 3500 gave 19 mph. Numbers looking better but still a little shy of expectation. Wondering if anyone running a four stroke 200-225-250 on a 23 can share their numbers? Thanks
Check with trever hicks on this board or look up his old posts.
Capt. Brian |
Schooner,
Your motor should WOT at 6000 RPM with a light load, indicating that you still need another 500 RPM or roughly 2 more inches of pitch. The 21" recommendation was a good one.
