OK - I've been living off my handheld, remnant from my last boat, and decided to get a fixed mount unit for my Seafari. I had the boatyard do the install on my last boat, and don't remember how it was layed out, or know if they cut the cable to length.
What is the general consensus on installing the antenna, where there is excess length of cable ? 1 - Cut to length to fit 2 - don't cut, coil the excess 3 - don't cut, stow the excess loosely / random 4 - other Appreciate your wisdom thanks Bill |
Cut to fit. Fewer problems from interference. Also, unlike other types of 2 way radios there is no significant difference in "tuning" from cutting the cable.
Old Blues
I agree with Roger. Even thou the VHF cable can be spliced, I think I would coil up the access just in case you change the mounting position at a later date and need more cable (Like up on a T-Top / Arch etc.) ![]()
I was always taught to avoid cutting if possible, Blue Seas cable seals are good for this. And take the excess and store or zip ty it so it lays against itself in straigh lines. No crossing or coiling of the cable for optimum performance. Anyone else do the same? Mine is setup this way but I have no comparison to see if it improves or not.
i left my excess coiled up under my console. have had no problems with the radio as of yet.
-evan |
im a #2- i coil mine up as well- i do try to keep it away from the coiled up gps cable and the coiled up radar coil and the coiled up transducer cable(s)
Contact Jim at BOE marine and order a Digital brand VHF antenna with your custom length. They charge ~$10 to cut/new connector and with their small machanical connectors they are easy to get through tight spaces.
There may be a few weeks delay and there is a 5' min length. I went the Digital route with only needing 5' and very happy! - Nick ![]() |
According to the instrucions from the Shakespeare Galaxy instructions -
"Route the cable to your transceiver, keeping it as far as possible from other electrical equipment and cables. The 50-ohm coaxial cable should remain at least 3 feet in length, measured from the point where the cable exits the antenna." My radio is mounted in my electronics box on the t-top with the antenna just a few feet away - did not want the extra slack coiled behind my other electronics so the 3ft minimum worked out perfect.
"Anything you let a dog do, you're training it to do." - 1977 23' Superfish ST250x Yam |
I just wish I could get rid of the bazillion feet of transducer cable left over in the console. Between the vhf, sonar, gps, navman, lenco tabs, trolling motors, stealth charger and assorted other "normal" wiring and cables, every little bit of cleanup helps on my boat.
