Currenty my console setup has a big piece of 1/4" starboard in the middle.
I am thinking of replacing it with either 3/8" or 1/2" starboard. I would go the thicker route because I have read that it is less prone to cracking. However, isn't it also harder to cut and install flush mounts? Also, what kind of saw & blades am i best off using? I have used a hand jig saw in the past but am thinking that I would be better off with either a spiral saw or a router. What do the experts out there have to say? Thanks, Peter
Since I am no expert I have used skill saws and jig saws with good blades. I will use a guide to help keep my cuts straight and then I sand. I have also used a straight edge and clamped it to the material flush along the edge I cut and then I used a sander that will remove the high points but the steel straight edge keeps it flat. I have always liked the thought of a table saw and always hated the idea of only using it 2 to 4 times a year and keeping it around all the time. My Dad did that and I can’t tell you how many times a year I would have to move it to get to something else.
FellowShip _______________________________________________ My motto: Just for the Grins ![]() |
Make a template of what size you want out of 1/4 plywwod.
then take that and two way tape it to your starboard that is cut just a little bigger. It will give you a sweet edge and exact shape as template. Make sure you use a router bit with a guide on it. |
I think starboard cuts very easily with a circular saw or table saw when making long cuts. When cutting with a jig saw or similar, you are right the stuff is hard to cut perfectly probably due to the heat of the slow traveling blade melting the plastic.
dixie plastic in ft lauderdlae cuts starboard w/ a router.
In that case why not use a Roto Zip Saw/
GARY 76 SEACRAFT CC INBOARD |
The bad thing about cutting starboard is the plastic shavings go everywhere. I have cut it with a skil saw with no problem, rotozip cuts it well but hard to keep it straight due to the high RPMs, hole saws are a pain because the plastic kinda melts in the teeth.
i was cutting my starboard with a battery powered circular saw. worked very good. i also rounded the corners with a jig saw and medium tooth blade. then i sanded it and its smooth. just need a router for all the edges
I just reworked my 23' console with 1/2" Starboard also. I flush mounted electronics and a small storage with recessed clear door. It machines easy, just lay out your lines accurate, measure twice-cut once!!
Very nice layout.
What kind od saw and blade did you use?
