Old 06-19-2007, 05:47 PM
JamesW JamesW is offline
Default 23 cc 1978 project
this is my first project boat so i am new to all this but luckly my parents own a boat yard so the the guys from the yard will be helping me when they can here is some pics. more info to come
Old 06-20-2007, 12:58 PM
LiveLine LiveLine is offline
Default Re: 23 cc 1978 project
Great boat....keep us posted.
Old 06-20-2007, 05:04 PM
peterb peterb is offline
James,
Hey, I recognize that boat. When you are done and that boat in the water you are going to be amazed.
I think that you know that I replaced that boat with another 23 (this one).
[image]http://[/image]
your boat is the ultimate beast. I used to take that boat in 4 to 7 foot seas and any newbie on the boat would be amazed by the ride. My new SeaCraft does not ride nearly as well (yet). I hope to fix that my getting the engines raised.
Best of luck.
Peter
Old 06-20-2007, 10:06 PM
turftime turftime is offline
peter do you like the bracket on your boat i was thinking about doing that myself
Old 06-20-2007, 10:03 PM
james i just bought the same boat with twin 175 and i will be doing the same thing this winter to mine. let me know if you find anything that you think i sould look out for this is also my first project boat so any advice will be great thanks
Old 06-21-2007, 12:09 AM
Nice project,
looks like you have the motor covered. Fuel cell replacement or refurb is normal stuff. From the pics it looks like an above average boat that should provide you a good project with minimal stuff to do to it.
Congratulations!
Old 06-21-2007, 09:18 AM
James,
How much fuel was still in the tank? I am guessing close to 100 gallons. Also, do you know if it got contaminated it all after it's one night soak?
Turftime,
The bracket is designed to give you more room in the back, as well as better engine performance (higher WOT and better fuel consumption). Also, I like the idea of a closed transom.
It does require it's own special maintenance (such as it's own antifouling paint and you have to makes sure that it does not fill up with water). Also, under my current setup, the engines are too low. As a result, I am not getting a great ride all of the time (too much porpoising). Hopefully, I will be able to remedy that.
Two other things. First, strong trim tabs are a must with the bracket setup. With a twin setup that's a lot of weight back there. Second, it you have a trailer you will probably have to get it adjusted to support the new weight distribution.
Peter
Old 06-21-2007, 03:01 PM
peter,
there was about 88gals in the tank there was no water from what I saw.
the boat is going to have a hermco bracket with either a 250 zuke 4 stroke or 250 yamaha 4 stroke. a brand new custom fuel tank.
i will not be able to work on her this week
because i going to alsaka to fish for a week but will report on my trip to alaska when i get back.
here are some pic of what i did the yard today since i could not work boat since i was only there for an hour
by the way thats not me in the red shirt i had the camera
Old 06-22-2007, 11:49 AM
James,
Good luck in Alaska. Fishing for halibat, salmon & ling cod?
I thought that the gas would be fine. I saw no leaking on the water. I keep saying it but you're going to love that boat when you are done.
Are you going to close the transom?
With the bracket have you figured out how you are going to use a 25" shaft yet?
Peter
Old 07-16-2007, 10:00 PM
peter will use the hermco bracket made for a 25 inch shaft. and up date on the project
well removed
new tank
the shop
