Where does everyone mount their transducers? I have tried a few places on the transom making sure it was properly inline with the bottom of the boat to reduce bubbles. When I get above about 1200 rpm I start getting bubbles causing the fish finder to go crazy.
I am thinking of mounting it as an in the hull config. Being a 20cc access to the inside of the hull is quite limited. Where have people had success mounting transducers so that there is no bubble interference when running at mid to high speeds? Thanks |
Center of middle panal starboard side. I wish I had a better pic, but you can see the transducer inboard of the trim tab. Mine works great at all speeds.
![]() The height and the angle the transducer is mounted has a huge affect. Good luck! Lloyd
1973 Seacraft 20' SF "Sea Dog" 1988 Tracker/Seacraft 23' WA "Salty Dog" |
Thanks Loyd...
I spent the day remounting it, tried to mount in the aft bilge under the false transom but it is so difficult to work in with only the small round screw plate in the stern/engine well. So, I cut a hole in the bottom of the rear bait well and mounted a 6" screew plate cover there. I then mounted the transducer to the bottom. Its probably about 2 1/2 feet in from the transom and centered. I used a small plastic peanut butter jar, cut down to be about 3" high and sealed it to the hull with lifecaulk. I just fill the plastice peanut butter jar section with water and drop the transducer in , screw the cover back on and it works great. This also leaves the transom clean. I had originally tried it just about where yours is mounted, but it just kept getting too much disturbance from bubbles at anything above about 4 knots. I see you have a tail, I don't so maybe that makes a difference.. Thanks for the pic and suggestions! Great forum! Aloha |
That's interesting, KBay. Very creative solution to a pretty common problem. Way to go. Can you post some pics?
Thanks, McGillicudy
These pictures are not the greatest, I had to take them at night with the flash so it was hard to get a good shot. I might be able to take some before work tomorrow.
Here is the water tight threaded port. http://share.ovi.com/original.aspx?c...080&size=large Underneath I lifecaulked the peanut butter jar to the hull of the boat... http://share.ovi.com/original.aspx?c...083&size=large Then fill with water and drop in the transducer... The jar is just big enough or my transducer so it won't move around. If the jar were bigger I would have used plumbers putty on the sides hold in in place http://share.ovi.com/original.aspx?c...082&size=large And then put the top on the jar.. I cut a slot in the top but be carefull the plastic cracks very easily as mine did. http://share.ovi.com/original.aspx?c...086&size=large Then screw the port back in tightly and you have your transducer installed and the bait well still works. Sorry for the poor pictures but I think you will get the idea. |
I had mine in the bilge and it worked great. I wasn't about to have holes drilled in a brand new transom and don't particularly find external transducers attractive. Other than losing water temp readings, I can't see any downside to putting them in the bilge.
