23 seacraft classic vs. tracker made
could anyone help me out with when tracker marine took over seacraft boats...did the hull change? thanks
Re: 23 seacraft classic vs. tracker made
The replys I have been getting so far are the design is pretty much the same the production methods are different. Older hulls hand made newer hulls assembly line production
The hull, design, and materials stayed the same. The labor and rigging went up and down, the rigging mostly down since 1986. I have seen good and bad potter and tracker boats, I haven't seen a bad csy or mosely era boat, but that may be because there aren't many of those around. Whatever you do, if your not sure what your looking at, get a servey done on it. |
Snookerd |
I would agree to the point they were heavier than they needed to be. Now on the other hand if you wanted to get in a fight with a dock or seawall that was good
They are the same hull and nobody has had any issues, most guys come out and say they love the new ones. There was 1 early 25 that was a nightmare for whatever reason, not sure of the real story as there are 2 sides always but that was 10 yrs ago.
Thanks for all the info on the history. I am looking at a 1989 23 CC and wanted to make sure that the boat, all things being equal, was as good as the earlier models.
I THINK Tracker Marine took over in '87.
Common Sense is learning from your mistakes. Wisdom is learning from the other guy's mistakes. Fr. Frank says: Jesus liked fishing, too. He even walked on water to get to the boat! Currently without a SeaCraft (2) Pompano 12' fishing kayaks '73 Cobia 18' prototype "Casting Skiff", 70hp Mercury |
SEC = SeaCraft Inc (Potter 1969 thru 5/80)
csy = Carribbean Sailing Yachts (1980-1982 23'& 27' SeaCrafts only) SIC = SeaCraft Industries Corp (1980 thru 1987 other SeaCraft Models) (Potter on Board of Directors approx 1 year after sale) TXY = Sarasota Marine Corp ('86-'88 csy Parent Co) SIC = Tracker SeaCraft of Fla (1987 thru 1990) all models SXC = Stern Craft Corp (1994 Silver King Parent then Tracker Parent Co in 1995) MIC = Silver King Boats (1994-2002 Mako Marine Parent Co) MRK = Mako Marine (2002 Parent Co SeaCraft from Tracker
we need a lifeguard at the gene pool |
courtesy of "PETERB"
Before 1972 . . . Hulls had 4 digit serial numbers . . . so they do not have SEC in their HIN numbers. They will have been assigned one from the state where they were first registered unless that state supports 4 digit hin numbers.
