Old 10-29-2008, 10:01 AM
savtower savtower is offline
Default Fuel tank installing. HELP!
Just removed my 79 MA fuel tank (70 gal.) and replacing it with a moeller tank. The moeller tank is the right height but the width is less than my opening. What type of material should I use to fill the gaps and should I put something on the floor like the foam I removed?
Old 10-29-2008, 11:53 AM
Default Re: Fuel tank installing. HELP!
Yes to putting something under the tank. A friend of mine bought 4 bicycle inner tubes that stretched around the tank like rubber bands. The don't slide, and absorb a lot of vibration.
Fr. Frank says:
Currently without a SeaCraft
Old 10-29-2008, 02:54 PM
gss036 gss036 is offline
http://www.yachtsurvey.com/fueltank.htm
This gives instructions for an aluminum tank. I am not familiar with the one you are doing though.
Gary
Old 10-29-2008, 09:44 PM
3rdday 3rdday is offline
Foam it in with USCG approved flotation foam try to find 6 or 8Lb density If it is a smaller tank you can probably use 4lb density. A large tank will have lots of fuel thus lots of weight, sloshing and pounding around and possibly crush collapse low density foam.
Old 10-29-2008, 10:26 PM
BigLew BigLew is offline
I strongly suggest you read the article cited from "yachtsurvey" and then decide whether or not to use foam. He discusses the consequenses of using foam in circumstances where moisture might penetrate the foam and come in continuous or longterm contact with aluminum. Just a suggestion.
Plan accordingly!
Old 10-29-2008, 10:41 PM
I believe moeller tanks are PE- polyethylene or polypropelyene. If not, my mistake. I was under the impression it was a plastic or poly tank. I would agree with you on aluminum tanks. you dont want to trap seawater near one of them, it will corrode.
Old 10-30-2008, 08:18 AM
I couldn't agree more if the Moeller tank is PE. The issue of aluminum is not pertinent if the tank is not aluminum.
Plan accordingly!
Old 10-30-2008, 03:43 PM
Another thing to keep in mind, is that the Moeller tanks will expand when they are filled with gas. I think you can find the rate of expansion, on there web site.
