Old 01-06-2009, 08:15 PM
tito tito is offline
Default stringer question
Its been a long time since i havent been on the forum and my proyect is been on a forced halt for lack of $$$$time$$$$ but Im about to resume the proyect. Today I was checking the stringer system and noticed that they are wood free or wood less or the wood took a vacation and hasnt come back so I was wondering if this is normal on these boats. It has a stringer system with bulkheads all in one piece pre made in the factory but like I stated before has no wood that i can find.
Does anyone have any input on this?
Old 01-06-2009, 08:27 PM
Default Re: stringer question
What year model is it. My 1984 23 has foam incased stringers from the factory. They are about 20-24 inches wide.
Old 01-06-2009, 09:02 PM
Its a 1979 bow rider. It has no wood or foam
Old 01-06-2009, 11:03 PM
I have a 1970 20cc, there was no wood in the stringers either, apparently for some years they didn't use wood, I filled mine with foam.
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
Old 01-07-2009, 01:41 AM
jboatdoc jboatdoc is offline
My 74 Seafari is only glass and foam
Old 01-07-2009, 01:31 PM
My 72 Seafari is hollow Fiberglass stringers, with a wood cored fbgls support down the kelson.
Fr. Frank says:
Currently without a SeaCraft
Old 01-07-2009, 11:39 PM
Carla could tell you for sure, but I think the last bowrider was made in about 1967 or 68, so if your boat really is a bowrider, it's a lot older than you think! They were strictly a Moesly boat, never made by Potter.
Click on this link to Moeslyseacraft web site to see a picture of the unique 1-piece molded stringer/bulkhead assembly that Moesly came up with for the 19. It was laid up separately and then bonded to the hull, possibly before hull was pulled from mold.
Old 01-08-2009, 12:13 AM
thanks for all the info provided.
this saves me a lot of work wich is definetly grat knews. I will tackle this by filling the stringers with foam and start the deck after that. That should keep me bussy for a while.
Old 01-08-2009, 12:57 AM
No need to add foam to the stringer unless you just want some more flotation; the foam provides no structural benefit. The 23's seem to have foam filled stringers, but it's just there for flotation, since the foam doesn't have much load-carrying capability. On the wood encapsulated keelson, most of the load is carried by the glass, so even if the wood rots out, it's no big deal structurally. The stringers in the 20's are hollow, were laid up separately from the hull and then installed about half way thru the lay up of the hull. Check the Boating Magazine article in the Literature section on the 20' Seafari - it contains a very detailed sketch showing how many layers of mat and roving were used in the hull and stringers.
