Anyone using the Volvo trim tabs? Anyone have any input? Couple of folks using them here in NC and swear by them. Thinking of putting some on the 23 CC.
Any feedback is welcome. Thanks, BA |
My buddy uses them and LOVES them. My dad just sent me a pair for my SC 20 footer, can't wait to try them out.
FishinDaze |
Can you post a picture after you mount them? I'm looking down the road for my 20 SF and this thread has raised my interest about the Volvo tab. The website I found didn't give any dimensional information and they looked much longer than a standard tab.
Will |
OK, I found the site with the needed info but would still like to see pics. Thanks
Will |
I have the trim tabs installed and have run the boat several times and must say that I am very impressed with them. They are very responsive and I can get the nose down as far as I need with these. Below are a couple of pics. They are definately a good idea with the bracket. I still have the Bennett system I took off, just didn't want to have to cut holes in the bracket to put the trim tabs back on.
are those your scuppers running out the sides??? if so how they work. better then out the transom???
BA....what model# did you go with? Thanks.
I have the smaller ones on my 27 and they work great. A few things to keep in mind. I did have the relay block go bad, but Volvo sent a replacement right away. You have to make sure the surface you are mounting them to is perfectly flat. I had a fiberglass backing plate made that worked out great. If the surface is not flat, they will bind, and I think that is why the relay block went bad. Now they run up and down with no resistance or binding. There is also a calibration procedure where you hold down the upper and lower buttons for 10 seconds during power up, make sure you do that during install, otherwise they will not retract all the way up. They are very responsive, and should never cut off your line if a fish turns and heads for the transom.
Dan
It's not a Small-Craft, it's a Seacraft |
I must admit they have a few qualities that probably are a good. But there a few thing that are not.
Good things list If you have a bracket boat they would not get in the way. They look pretty cool. Price is good. Bad things list Got to have more drag reducing performance with the 90 degree angle. Since they dont go back 12 in the water it would keeps the boat from acting just a little bit bigger in seas. I did here of One case where the 90 degree lip got hung up on something floating in the water when the boat ran over it and ripped it off. Caused a lot of damage to the transom. FellowShip Just for the Grins ![]() Official Antique Classic SeaCraft Owner |
Bushwacker: Any response? You are our engineer on call
![]() They would be a nice neat package.
