Hi there, just bought this 18 and couldn't put her away for the winter without knowing its quirks... Think I found one.
1st - the boat has a mangled prop. (not by me!) Its very evident in the picture provided. Curious how you think this mangled prop would affect performance? The boat ran great today. Slid onto plane easy and guessing WOT maybe 35MPH (just a guess) 2nd - Tremendous spray coming up from the transom when on plan. Hope its evident in the picture, best I could do. The motor has those bolt on fins on it by previous owner. Not sure why they are on there. There is NOTHING hanging below water line on transom aside from the sender from the fish finder. I ruled that out because the spray is equal on both sides. I was hoping you all can weigh in on a few things. 1) Use of those bolt on fins 2) Mounting position of the motor. Should I raise it? You can see in the pic its on the top bolt of the motor mount. Thanks all for your thoughts... ![]() ![]() ![]() ![]()
1988 18' Seacraft 1988 Mercury 115 |
1. Fix/recondition the prop
2. Raise the motor 1 hole. 3. Re-assess Try this. Really.
Yeah, a new prop is in the works, asap! Looks like I have 1 hole on the bottom motor mounts I can raise before I have to drill new holes which I'm not keen on doing.
I'll report back on new prop action after I get'r done. Curious why previous owner put those fins on.
They help the boat plane at slower speeds, cheap trim tabs and not as efficent, they do work though. They will provide spray, particuliarly if the engine is mounted to low, keep the cavitation plate about 1" to 1 1/2" above the keel. They also cut some top end.
Yeah hard to imagine the boat yard that sold this boat in FLA. thought that those bolt patterns were correct. I don't officially know what is correct but I'd prob. lean toward mounting bolts in the middle of the bolt pattern which would allow for motor up down adjustment without new holes.
That said I have a 1 hole adjustment left. I'm not sure where that puts the cavitation plate on the transom, I'll play with that tonight. Never the less, I'm going to rip those dol fins off as I think they look silly and I think the payoff to be minimal. New prop on the way, the mangled one was a 13.25x17. I'm trying out a 13.25x19. Tx for your previous reply!
I'm no expert and I don't know if it would have any effect, but, looking at the first picture, it looks like the motor is tilted to the side a couple of degrees. However, if you look at the top bolts in the transom, they appear to be off a little, but, in the wrong direction. (Might be my glasses).
I'll check on this tonight!
