Old 09-15-2010, 08:56 PM
geesea geesea is offline
Default wet sanding hull
Can anyone advise the initial and final grit to use wet-sanding a hull? I just removed an ugly painted on boot stripe using paint stripper and want to even out the gelcoat on my 23 savage. Compounding was not aggressive enough.
Old 09-15-2010, 09:38 PM
Default Re: wet sanding hull
If you have serious oxidation on the gel coat I would start with 600 if not start with 800 then to 1200 then up from there to 1500 before you start waxing.
FellowShip
Just for the Grins
Official 23’ SF Antique Classic SeaCraft Owner
Old 09-15-2010, 09:55 PM
If you use Poly Glow instead of wax, you can finish with the 800 grit.
Dave
Blue Heron Boat Works
Old 09-16-2010, 12:10 AM
Just buff it with tigercut. Then work your way down the line.
Old 09-19-2010, 08:56 AM
red20 red20 is offline
I have a Harbor Freight air powered orbital wet sander that makes the process VERY easy.
Old 09-20-2010, 09:39 AM
SBD SBD is offline
I have been wet-sanding my arm off!!!Considering getting a air wet sander...gotta pn for the one from HFT?
Were do you get paper for it?
Thanks!!!!
