Old 10-10-2010, 07:34 PM
tomfl tomfl is offline
Default Livewell options on a 20 footer
Longtime lurker here, previous seacraft owner as well (23 footer).
Have had my eye on a 20 footer for many years, but the lack of livewell options moved me to getting into a hewes light tackle.
I'm thinking of going back to a hull with more deadrise, aka a 20' seacraft but am hesitant to give up my ~60 gallons of livewells on the hewes.
Anyone out there that does a lot of live chumming and live baiting with their 20' hull that could show me some pics of their livewell setups?
Thanks
-T
Old 10-12-2010, 12:47 PM
Default Re: Livewell options on a 20 footer
I had the same issue, the SF20 IMHO would have to use a leaning post and baitwell setup. I was lucky enough to find a Master Angler which was designed in '75 because of the popularity of live baiting. I have never had any issues keeping bait even overnight unless the water was really hot and no current, so if you can find one that may be the ticket.
Old 10-18-2010, 05:50 PM
What's the livewell capacity on the old Master Angler setups?
Also, thanks to everyone who's posted pics. Seems like the under console is a popular setup. Anyone run feed and drain hoses under the deck to keep the floor clean of hoses?
-T
Old 10-18-2010, 07:42 PM
Yes, but you either have to cut out the in deck well or use pie plates. I cut it out. Easy to access bilge now.
Cheers,
GFS
Old 10-18-2010, 10:08 PM
Not real sure the capacity, maybe 10 or so. I have a Master Angler and ran the hose under the deck. Right on top of the gas tank. Some 90's and some thru-hulls through the floor with a shut off. Works great and no hoses on floor.
Old 10-19-2010, 08:48 PM
not sure how big but works good for tons of white bait and greenies pins and small mullet. but may get tight for very large baits like big runners or large mullet
Old 10-12-2010, 07:28 PM
madangler madangler is offline
I do a lot of livebaiting out of my 20fter in south florida. I have a simple yet effective setup with a 40 gallon tank behind the leaning post, and a 1100 gph transom mount pump. Easy to put together and it keeps a ton of bait alive. Make sure to add a shut off valve at the tank if you use this method, otherwise the transom mount pump will pick up water when it is off and you are moving
jerk on one end waiting for a jerk on the other
Old 10-12-2010, 08:59 PM
Everyone has their own path.
Cheers,
GFS
Old 10-13-2010, 04:02 AM
yes sandy and as a great scottish poet once said - I I took the path less traveled by
LOL
actually I think he was the only famous scottish poet, we're not usually known for our prose I guess, I know I'm not
Old 10-13-2010, 08:48 AM
Scottish poets? Have you seen the price of ink lately?
