Old 03-17-2011, 04:50 PM
Default 97 Merc 175 EFI
Looking at a 97 Merc 175 EFI that the owner says has either a bad piston or rings either way it's locked up.
The rest of the engine looks good except for the skeg that I'm not surprised since it's on a flats baot is missing a little.
I can have the engine for $200
What could be the cause to lose a piston or rings ( I know it hard to say since I have not taken off the head) but what do you think would be the costs involved?
he states that everything else is ok with lower unit and trim and electronics but it would be hard to check since its off the boat
OPINIONS PLEASE!!!!
Old 03-17-2011, 07:38 PM
pelican pelican is offline
Default Re: 97 Merc 175 EFI
"piston" ? "rings" ?
pull the cylinder heads off-see what everything looks like inside the cylinders - if the tops are blown or melted off the pistons,it's a result of detonation...it usually effects the top cylinders-heat rises...problem comes in if the crank is damaged...usually,what happens is a cylinder detonated-and "shrapnel" is shot around-blocks are damaged,rods are damaged,and cranks are damaged...
either way,the engine's gotta come apart,to really make a diagnosis-either way,you're looking at either a full powerhead overhaul,or,a new powerhead...my opinion-$200,no deal...you're buying a cat in a bag,yep,you can see if the lower unit shifts,and the hydraulics-tilt and trim work-but,that it...it's all a guess...what caused the failure ? engines don't fail on their own,something causes the failure...personally,i would pass on that deal...a 14yr old blown engine,is no deal @ $200...
Old 03-17-2011, 08:41 PM
Losing a piston won't lock it up - a rod yes - chances are the block and crank may be shot - the LU and electronics are worth more than 200 if you want to part it out. You have the switch boxes maybe 150 - ECU - LU - stator ect. On the other hand a drop-on PH could be about 2K, check at Scream & Fly for PH's and drop-ons. You can also check for prices on the parts you have.
Just don't count on that being rebuildable
Old 03-17-2011, 09:02 PM
that engine has cdm's-,no switch boxes-old school mercs have switch boxes...
problem comes in with,you don't know if any of those parts are good-ask yourself the question,"would you buy a used ECU"...
Old 03-17-2011, 09:35 PM
Yea I thought about it all afternoon and I'm going to pass
Old 03-17-2011, 11:04 PM
very smart man you are !
