Old 04-08-2011, 10:41 PM
shana shana is offline
Default clean and wax
what is a good wax to use that not alot of buffing on my 75 seafari thanks george
george j victor jr
Old 04-08-2011, 10:54 PM
BigLew BigLew is offline
Default Re: clean and wax
Best I ever used was the Colonite paste. Not easy or hard to apply, just seems to last and do the job. Remember that I am in the more northern clime's though, including a shorter season.
Plan accordingly!
Old 04-08-2011, 11:09 PM
Forget about wax - give Polyglo a try and you'll never fool with wax again! PowerBoat Reports tested it against a couple other coatings for over a year and said all the marketing claims for it were basically true. I believe it's some sort of urethane emulsion, have used it for several years and am convinced. Other folks that have seen my boat with it's original 1972 gel coat have also tried it and concur with what I've learned. If you leave it exposed to the intense S. Fla. sun & UV, you'll have to redo it every year, but if you keep the boat covered when not in use, it's good for 2 or even 3 years. If your boat is badly oxidized, you might want to lightly wet sand it with something like 800-1000 grit first. The HD cleaner that comes with the kit is pretty strong and will leave the surface very dull looking. The first couple of coats will show streaks, but after 5-6 coats it has a "wet" look that is an amazing transformation from what you started with.
However if you're a glutton for punishment enjoy compounding, buffing and waxing, PBR tested all the popular waxes several years ago and concluded that Collinite Paste Fleetwax was the most durable. (good for ~ 6 months in S. Florida.)
Old 04-08-2011, 11:53 PM
I'm going to try PolyGlo in a week or so.....
Old 04-08-2011, 11:59 PM
red20 red20 is offline
compound with 3M micro (or wet snad if necessary w/ 1200 - 1500) and then colonite wax. rewax every 3 months at a min if in south FL.
PM for full details.
Old 04-09-2011, 12:35 AM
GodsReel GodsReel is offline
would you suggest polyglow on a painted boat
Old 04-09-2011, 07:43 AM
where do you buy polyglow?
george j victor jr
Old 04-23-2011, 07:17 PM
Default Re: clean and wax - Poli-Glo !!
I'm going to try Poly-Glow in a week or so.....
I Did the Starboard side of my boat today with Poli-Glow. Wow what a difference!! Very happy with results. Surface prep is the key.
Before:
After:
Looked so good, it should be illegal!! No ticket though.
