Old 04-27-2011, 10:51 PM
abl1111 abl1111 is offline
Default Trailer Question - 23'
I have a 23' Tsunami with an older trailer that I use (2)X a year - in/out - no more than 3 miles round trip.
The trailer is an old Rocket, that has had some good 'ole boy ingenuity put in: it's a 'fusion' of a bunk w/ keel rollers. It ain't really pretty...
The 12" keel rollers seem to give me a problem in that it's tough to get the boat centered just right - or the roller bracket will scratch the hull. Usually the 3rd roller from the rear does the damage.
People from the site have given me input before, i.e. bring bunks to center more etc. ( I can't do this due to my raw water strainer being in way - it's an i/o ).
I was wondering - do I need keel rollers at all ?
And, if not, what is the best thing to put on top of the bunks to get the boat up and on ?
How far do you drive your boat up on the trailer before you have to winch ? Can you winch this heavy hull onto bunks ?
I have thought of as many ways as I can to line the "V" of the hull perfectly, but none seems adequate...
Any help here ?
Old 04-28-2011, 09:40 AM
Default Re: Trailer Question - 23'
Stoltz makes a 12" urethane self-centering roller that worked for me. It looks like it has a really coarse thread cut into it.
Old 04-28-2011, 01:13 PM
Any help here ?
Leave the main bunks alone and add forward keel bunks made of 2x6. Guaranteed to center you on the trailer every time. I got the idea from someone else here on CSC a couple years ago. Looks like this:
Blue Heron Boat Works
Old 04-28-2011, 06:18 PM
Any help here ?
I did the same thing for the 21 and it works great.
Old 04-28-2011, 09:09 PM
Ditto and double ditto. I had the same front V-bunks installed on my new trailer a couple of years ago. The only thing I did different was I took off the carpet and used plastic bunk slides on top of the wood. No marking, easy slide on/off and no wet carpet against the hull.
Old 04-28-2011, 10:19 PM
Thx guys. I'll give it a try. And for bunk carpet / plastic 'glides' - which do you recommend ?
How high and thick are your bunks ? Mine are 3" thick x 8" high.
Island - where'd you get your trailer hardware, i.e. V bunk brackets ?
Not being a trailer guy - just in / out and never shown how it's done ( just basic know-how ) - how far in should I put the trailer in the water when I try to load ? I always wondered if I was in too deep ( or not enough ) ?!
Old 04-29-2011, 12:30 AM
another vote for forward v bunks. going to do it to my other boat too when funds allow.
Old 04-29-2011, 08:30 AM
Local trailer shop. The whole kit was $125 and $150 installed.
