I know this has been covered alot. Not a speed demon, etc.
Just looking for some insight from guys running 115's on a 20. I found a smoking deal on a brand new Yamaha 115 2 stroke carb engine. Late model 2007 never been installed leftover. I had my heart set on a Zuke 140 but this deal is half the price. Just looking for some reassurance that the performance is adequate. I already have a fully restored 23. My 20 is going to be for running around, back bay fishing, etc. Anyone care to share performance numbers on a 20 SF with a 115 2 stroke? |
Different animal, but back in the late 70s, my dad bought a 20' Grady CC with a 115 Rude on it. From what I remember, that boat would top out around 33, but I don't know what kind of load it had when it did it. I imaging your SeaCraft would be a few mph/kts faster. Not sure of the cruise numbers.
I saw the ad for that motor as well. Good luck. That's a good buy.
Brian 1981 Mako 17 |
Personally, I think 115 hp is plenty on a 20.
I run a 1983 115 Merc Inline 6 on a Seafari. I'm pleased with it performance wise. I use a Quicksilver Black Diamond 13-3/4 x 15 alum prop. Out of the hole and on plane instantly and tops out at 36 mph @5500 rpm. Idles around at just under 2mpg. 3500 rpm gets 2.3 mpg and 21mph 4250 rpm gets 2.5 mpg and 27 mph 5000 rpm gets 2.4 mpg and 31 mph 5500 rpm gets 2.1 mpg and 36 mph My motor is only about 300 lbs but I have 2 group 27 batteries in the stern hatches. The Yamaha 115 is about 60 pounds lighter than the 140 Zuke. That can be significant on a 20 inch transom. A little less concern on the 25" transom. Also worth considering are the E-tec 90 (325 lbs) and Etec 115 and the 115 Optimax (both about 375 lbs). Keep us posted. Must be a bummer having to make such a decision ![]()
Brian - i pulled the trigger on it. It's a good deal on a proven engine and will save me alot of pennies.
McGillicuddy - if i can get those numbers i will be perfectly happy for sure. Do you stay on plane at 21mph without tabs???? |
mrobertson,
Nice score. Yeah, I stay on plane easily to about 15mph. I will be putting trim tabs on as I seem to lean to port a wee bit when running NW. The gear ratio on the Yammie is also 2:1. For me a 17P was ok but when I went to a 15P every aspect of performance improved. Including top speed and economy. I believe you'll get better economy with that Yamaha - probably over 3 mpg at 4000rpm. I would love to see what that engine does with the same prop I use. You might consider a 4 blade semi-cleaver prop as you'll have more weight aft in the cc. Check out PowerTechs SCD4. That Yammie IS a proven motor. If you can, get the Yammie controls, everyone claims they're great.
I'm very interested to see what i get out of mine.
I cut the tank down to 50 gallons and im moving it forward as far as i can. likewise, my batteries will be under the console. I mostly do fly/light tackle fishing so i'm usually pretty light when fishing. im thinking more and more this 115 was a good idea, im stoked!!! |
Congrats, nice score. Good Karma!
I run a 4 stroke Yamaha 100 in a 20' master angler. Not a speed demon, but tops out at 33 dragging a hydroshield skeg mounted hydrofoil thru the water. Plus I have a kicker on the stern, too. Cruise is 20-24MPH.
I think a 115hp two stroke would be great. You wouldn't need the hydroshield so it should be faster, so Bushwacker's 37MPH estimate makes sense to me. |
