Old 12-05-2012, 09:50 PM
Default Count your blessings southern seacrafters
This is how I have to fiberglass in the winter up here in the northeast. Probably not the safest thing but I'd rather fish in the summer than work on a boat. The a frame is my daughters swing set, minus the swings. A propane heater and drop light and presto, make shift fiberglass shop in December in the northeast. I know the pics suck but here's what I'm dealing with...
Old 12-05-2012, 10:07 PM
Necessity is the mother of invention...Good hustle!
Old 12-06-2012, 10:26 AM
ct9amr ct9amr is offline
Get er Dun...
"the southern folks can translate for you. :-)
Glen
Old 12-07-2012, 10:18 AM
GoodChance GoodChance is offline
That sucks! I remember the mid-Atlantic and NE winters. Plus the heat/humidity of the summer.
75 degrees here virtually all winter minus a few days where it might only get to 60 with a passing cold front. But we do have warm summers.
The Idiot Who Re-Built the Burnt-Up 35 Duffy
Old 12-07-2012, 10:43 AM
bigeasy1 bigeasy1 is offline
Keep up the good work.
I know how you feel,I did the same over two winters in Mass on my 23 project.Tarped in enclousure with propane heaters and two feet of snow on the ground.Did the transom in February.
I actually liked doing the glass work in those conditions as you had a lot of time to work with the mix before it would kick.
Did the work in the cold and once it was where it needed to be,we'd crank up the heat until it cured.
Hey,I have no idea how the southern boys on this site do the beautiful work they do in that heat,my hats off to them.
Here's a couple pics of my resto enclousure.
__________________________________________________ ________________________
All this,just for a boat ride
Old 12-07-2012, 10:40 AM
We will... I'd probably blow myself up! Be careful with fumes. Particularly, acetone vapors are heavier than air, the vapor tends to settle at ground level. Highly flammable, you know the drill.
Old 12-07-2012, 07:47 PM
Nice. I'd like something as big as that but we don't have the land to do it down here.
Old 12-07-2012, 10:10 PM
it can be amazing warm in there I used to have a camvas shop in new Hampshire and it I had to put boats in a cover it tent in the winter I had a salamander on a thermo swich to keep the heat down id be in there in the snow in my t shirt, im sure now that im used to florida il be wearing a sweatshirt now
82 seacraft 20SF
Bayview Canvas
Old 12-08-2012, 12:22 PM
oldfielder oldfielder is offline
One thing I learned about propane heaters last winter redoing an 18 foot Steiger deck and stringers is that they create quite a bit of vapor, so depending on what you are doing just keep an eye on that. Depending on the dew point, temp, etc,once you turn them off you can actually create a situation where you create enough vapor inside your structure that you will get condensate once you shut the heater down.
It was more important when painting than when glassing.
Old 12-08-2012, 03:50 PM
Yup,you got that right.
A good friend of mine finished off a 30' South Shore down east boat in Maine in a beautiful structure that he built.He glued up several large bows out of 1x3's (like trusses),installed them on top of a 4' high knee wall,and then had the entire structure shrink wrapped.Even had an aluminum storm door for entrance.It was huge space.
He heated it with an old warm air furnace,with flexible ducting that he could move where ever the heat was needed.
The first time he fired it up, it was thumbs up,then after a while in the cold Maine temps with the heat from the furnace warming the interior,it basically started raining inside,from the large amount of condensation.
He had to make a rain catcher out of more shrink plastic hung about a foot from the top cover which directed the water out of the building.
