Old 05-06-2016, 06:31 PM
Rbauer Rbauer is offline
Default New owner of a 78 Seacraft 23
I have just picked up my first seacraft . It is a 78 23 cc that was converted from a stern drive to a outboard application with an Armstrong bracket. Does anyone know if the stringer layout was different for inboards/ outboards of this specific year?
Old 05-07-2016, 10:08 AM
FLexpat FLexpat is offline
I'm pretty sure the stringer arrangement is the same - for the I/O they just glassed in motor beds made of 2x6's.
Old 05-07-2016, 09:15 PM
Default 78 stringer
Thanks that helps a lot. I have been looking specifically for io restorations and now I can look at any 23 rebuilds of that time and be ok. I have a void where the engine was and they made a large hatch with starboard. I am trying to make a decision as weather to use it for a bit or put in a new deck and fuel tank/ tanks. Plus they did a sloppy Armstrong installation.
Old 05-08-2016, 07:40 AM
Sloppy bracket installation warrants a do-over ��
Old 05-08-2016, 10:32 AM
Default Pix of sloppy installation
It appears that they lag bolted the ends and even though they through bolted the middle there is a large seam of 5200 throughout. I am also not very happy with the cut out around the trim tabs. Wondering if I should try to clean up existing or get a whole new bracket- any suggestions?
Old 05-08-2016, 10:37 AM
Default Another pix
Another pix showing cut out
Old 05-08-2016, 10:43 AM
Default A better picture
I hope this picture comes out better
Old 05-08-2016, 10:56 AM
Default Full top view
Top view of the bracket
Old 05-08-2016, 10:54 AM
It seems the transom has a bit of a bow to it...how about a wider angle shot??
Old 05-19-2016, 05:42 AM
Rufneck Rufneck is offline
Has anybody found a trim tab that doesn't have such a long ram that requires cutting notches in the transom? I have a Sceptre with a bracket already installed and I'm really struggling to find a trim tab that is small enough to fit in the available space.
