My old fuel tank hatch covering the 40 gallon tank coffin was soft and very heavy from years of being reworked and lots of screws put into it. So I borrowed some tips from others here and scabbed together a melamine, MDF, and modeling clay mold.
Then I vacuum bagged a carbon, vinylester and nidacore layup. Gel coat down first. But I hurried and the gel coat hadn't cured enough so I got loads of print through. Then I forgot the breather material for the vacuum bag (doh!). So I got a dry laminate in the center under the vacuum port, so I had so re-wet the center with a wet layup and no vacuum and just peel ply. But it came out ok in the end. Fairly light, but not nearly as light as if I was able to correctly bag it. It was 17 lb for the hatch which is about 63" x 27", plus gel coat. I used aquarium "aragonite" as sandable anti-skid. $1 a pound at Petco, and a color match. ![]() |
A few more pictures.
Material list:
Melamine $35 @ Home Depot Primed 11/16" MDF trim $15@ Home Depot. Enough for two layers. The second layer is spaced out 1/8" to develop a line to trim to. PVA Gel coat, 1/2 gallon minimum 1.5 gallons vinyl ester resin 6 yards cloth (carbon is light, probably similar to 9-12 ounce glass??) 10mm 3/8" Nidacore (might be 7/16") Super 77 spray adhesive to hold MDF down so there are no holes for vacuum leaks 18 feet of butyl tape Stretchy bag Peel ply Don't forget breather! I heat poly pillow stuffing works. |
Looks good! I need to do something similar on my aquasport but I think I can reuse the old skin and just recore it.
1971 Potter built center console. |
It might be faster that way. Unless the gel coat needs fixing. Then it might be a tie. And no grinding.
Gelcoat is good on this one. Well. As good as it's going to get. This boat is just temporary until the SeaCraft is done. So like another 5 years. lol
